Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
I have a laars lite 2 manual controls natural gas. The unit starts up runs strong for 5 mins shuts down restarts runs for now only seconds and shuts off
    Problem Solver:
  • 11 Answers
Sounds like the hi limit switch is shutting it down,because it is not getting enough water,cloged filter, valve to heater notopen,bypass valve not closed,open up the water releif valve with the pump running should be alot of water running coming out of it.
Posted on Jul 11, 2010
Laars Pool Heater, pressure valve or something else,
bad pressure switch or incorrectly set should have no continuity when off it should when running put on 2000 for ohms should have 500 millivolts when off then turn on and it will start counting down at about 200 should light make sure all connections are good and all safety circuit is good
Jun 24, 2015 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater runs about 40 min then shuts down . replaced water temp sensor and it still shuts down
make sure it is a propane heater propane burns hotter than gas if not correct heater it will overheat if ok check gas pressure if not enough heater will overheat you also might have too small gas line and are emptying it
Oct 10, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool heater kicks on and off
safety switch is opening and closing, or issue with gas valve coils
Sep 17, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
We have a Laars Lite 2 which will fire and run for about 5 minutes then shut down. We changed the 135 and 150 limits as we noted a drop from 24 to 14.6 V. It appears to me that the unit is over heating. We...
make sure correct gas pressure if too low it will soot up and overheat sounds like transformer is going should be 24 volts if not pressure switch wont stay on also check the manual bypass by plumbing side if spring is bad water will not go through the heater correctly
Jul 02, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
We have a laars lite 2, when we openned the pool
Thank you for posting your question here on Fixya.com.
It could be...does it open up at the point the heater shuts down? Check it with a DMM to see. It is more likely an issue with flame recognition off the pilot/ignitor. Check them for rust that would cause a faulty connection.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Teledyne Laars Lite pool heater Model LLD 250N. When I turn the heater on it will run for 10 minutes and turn off. If I turn the power switch off and right back on it will run agin for 10 minutes...
It sounds like your pool heater might have a defective controller (the part, not you). Check the controller and replace if necessary. It could also be that you need to cycle the ignition sequence until the air is out of the gas line. It could also possibly be that your gas valve needs to be replaced.
Pool heater will not stay lit
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Apr 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Burner cycles on and off within 2-5 seconds. What could the problem be? Model Teledyne Laars LLD250N
Sounds like the flame sensor. If the sensor doesn't see a flame, it shuts off. Good luck...Lee
Oct 31, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Swimming pool heater
try removing and cleaning flame sensor with fine steel wool.its located in lower end of burner box,usually opposite side of ignitor
Sep 02, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
243 people viewed this question
Top Lite On Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
