Question about Haier HPR09XH7 Portable Air Conditioner
My portable air conditioner Haier started linking
My portable air conditioner Haier started to link water. It looks like it is not evaporating anymore, Somebody knows what could be causing the issue?
  • 10,865 Answers
Hi. Check the drain hose and look for kinks and partial blockage. Even algae can often block these tubes. J.
Posted on Jul 06, 2010
Testimonial: "There was dust covering the entrance of a tube where the water used to flow and evaporate, it was right beneath where the air filter is located. Removed the dust and is working fine again. Thank you"
Leeking water a lot
Condensate water accumulates in the evaporator.There is a tube that drains the water out of the evaporator to the condenser side where the fan picks it up or an external drain. The tube is plugged. It needs to be cleaned out.
Jul 05, 2015 | Haier 12,000-BTU Commercial Cool Portable...
Haier CPN12XH9 Portlable Air Conditioner/Heater - The upper water plug (which I can't find a picture of on any manual) accumulates water while the lower tank (where water should be) is dry. Unit is only...
Not up on the unit, but water condenses on the evaporator of an a/c unit dropping onto a tray, as self evaporating, would assume that the drain from that tray is fed to the top of the compresor, which will have a tray around the top, heat from the compressor will evaporate the water, same as with a fridge. In dehumidifier mode, water would need to be collected, rather than evaporated back into the atmosphere, defeats the object other wise. so is lower tank around compressor? that would be for a/c mode upper tank for dehumidifier
Aug 05, 2014 | Haier CPN12XH9 12,000 btu Portable AC Air...
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
Need to obtain a operations manual.
To download the Owner's Manual for your Model Haier Portable AC. Go to the following link and oat Product Support and Downloads and click on your model in the lower left of the page.
http://www.haieramerica.com/12-000-btu-cooling-11-000-btu-heat-capacity-115-volt-portable-air-conditioner-cpn12xh9
I hope this information was helpful. Thanks for choosing FixYa.
Aug 26, 2011 | Haier CPN12XH9 Portable Air Conditioner
The cover that goes on the back where the water can drain out is missing on my unit. do you know if I can buy a replacement
Casie, Haier may be able to help you with that specific part. Contact Their Customer Support Dept
1-877-337-3639 or Go to the following link http://www.partlinx.com/haier.asp . In either case, you will need to have the correct Model Number, handy.
I hope this helped you. Good luck.
Jul 11, 2011 | Haier HPR09XC7 Portable Air Conditioner
The air coming out of my Haier CPRB09XC7 Portable Air Conditioner has gotten warmer and dryer. I'm sure that i need to add water but i do not know how as the manual was lost a while ago. Do I just need to...
Actually, sportsfan, you don't need to add any water. In fact, there is no way to do it. Your unit works much the same way a dehumidifier does with auto evaporation function. In other words, it collects the humidity out of the room air a evaporates it, so there is no water removal on your part involved. While this water is being evaporated, it's also being cooled, so that cools your room. The hot air of the unit running is exhausted out through the window vent kit.
To replace your Owners Manual call Haier Customer Support 877-337-3639
Hope this helped answer your question. Please let me know. Thanks.
May 04, 2011 | Haier CPRB09XC7 Portable Air Conditioner
Fills with water, doesn't evaporate. Leaks. HAIER HPR09XC7
There is nothing to resolve. Your humidifier is working properly.
A humidifier works by condensing water out of air. This is the job of the cold coil, which you have found to have water dripping off. The Warm coil is not intended to re-evaporate the water, as this would just bring the relative humidity back to the origanal high level, rather, the warm coil is used to re-warm the air, going back into the room so the room does not get too cold. It is normal to have to empty the bucket and restart the process on a periodic basis.
Jul 20, 2010 | Haier HPR09XC7 Portable Air Conditioner
I have an amana self evaporating portable ac for my 500sf condo. I have had to unhook it and roll it outside 4 times to drain it. Lately water is now spilling out the back vent on to my floor. What's the...
It appears to me that because of the small size of your condo, you are just recirculating the humidity in the apartment. The unit is condensing the moisture in the air and then reheating it in the pan causing it to evaporate back into the air. The unit is working properly but the humidity level in your apartment continues to rise. You really need to add a drain from the pan of your portable air conditioner.
Jul 20, 2010 | Amana AP076E Portable Air Conditioner
Air Conditioner/Heater not working for more than 2 hours.
If you are running it in a very humid envioronment then it will make more water than it can evaporate off.
Nov 10, 2009 | Haier (HPE09XC6) Air Conditioner
I have HAIER HPAC 99ER Portable air conditioner and just quit working. There is a red flashing light blinking.
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
Jul 19, 2009 | Haier HPAC99ER Air Conditioner
Haier HPR09XH7 Portable Air Conditioner Logo
575 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
