Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Tv is not comming on when i plug it in it clicks the clicks again
After the two clicks the power on indicator button flashes 5 time and turns of and starts the process again
  • 58 Answers
Check for open resistor r800. 1.5k 5watts. Goodluck.
Posted on Jul 06, 2010
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
My TV on button is not turning the TV on. I tried the remote as well as the button on the TV.
Now,what happening to the tv power LED light indicaton,when u turn on the tv now?Tv don't have any power LED light incation at all or power LED light indication is flashing?Check ur power source with other devices,see if the outlet is the problems,if tv still have no power to the tv all.Tv LED power light indication is flashing?Tries tv unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.Now tv should work be again.Still have the same problems,this indication ur tv have a bad or a dead power supply board.That the board,where the tv power a/c cord plug into it.If u understanding basic electronic and have all the tools.Take the tv backcover aparts.Check the tv power supply board carefully for dying capacitors parts,these capacitors parts are dying or dead,most of the times they're bulging up or puffing up onto it tops.Replaces these capacitors parts with new capacitors parts with the same micro ferid but higer voltages like about 5 or 10 voltages higher for better heat resistances and last longer.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 13, 2011 | LG 37LP1D 37 in. LCD Television
How do you turn off the little red filter llight above the low speed indicator?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 28, 2010 | Filter Queen Defender Air Purifier
Blinking red light above the lowest setting on filter queen defender air purifier.
Sep 23, 2010 | Filter Queen Defender Air Purifier
Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
  6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
Please let me know the code you got and I'll tell where the problem lies and how to fix it.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I have spent about 4 hours tonight researching several tech sites and the Sony service manual for the same problem with my Sony KV-32HS510 unit. I was able to download the manual from a website http://www.eserviceinfo.com/downloadsm/31649/Sony_KV-32HS510.html and a TV Repair training lecture paper at http://www.repairfaq.org/sam/tvfaq.htm#tvhvp .
These TV sets have a safety feature where it will shut back down if a high voltage is indicated. Unfortunately, the electronics for these safety features are not very reliable and give false indication. Letting the unit sit off lets the capacitors leak voltage as well as cool off. These two factor help with the unit not falsely indicating a high voltage condition.
The D Board seems to be the most common failure component, but a 6 times flash could be an overcurrent/voltage failure from the A, B, or M boards. A 7 times flash is a Horizontal Deflection Stopped error with no additional information given in the manual for a fix. Again, in most blogs, the D Board seemed to the source of the failures.
A refurbished D Board part no. A1300319A can be bought for around $200 with a new board at $550 per the www.partstore.com site. Then add $100-$200 for an actual TV service technician and you have a repair bill approaching the costs for a new flatscreen TV.
Some tech types posted that they have actually repaired their boards by replacing individual components for around $40. You may find a service shop that can do the same component level repair at the $100-$150 level cost. It turns out that the closest authorized Sony repair shop is 2-1/2 hours away from us. Good luck finding someone close by.
We were able to get our TV to come back on after dozens of attempts and plan to leave it on until it dies all together. I may attempt my own D Board replacement when the time comes.
Dec 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
