Question about Mitsubishi WT-42311 42" Rear Projection Television
I have A Wt-42311 Tv problem having is either by remote or switch to turn power on i switch it on starts up and shuts off in 3 to 4 seconds. simple fix or?
  • 58 Answers
Mits sets give codes for different failures. By holding down the menu and device buttons on the front panel you can get a 2 digit code that will tell you what is wrong with the tv. The digits are seperated by pauses. 2 and 2 is common and points to a convergence failure. That's the simplest repair you can expect. Goodluck to you.
Posted on Jul 06, 2010
When I go to turn it on it clicks and then clicks off
do the self check this model has and let me know what you find:
when it shuts off press ON THE FRONT OF THE TV both the menu and input (or device) buttons at the same time for at least five seconds and release both buttons.
The power light will blink a two digit error code.
for example---2 blinks, a pause and 2 blinks (this is the most common error code)
Let me know what code you find and I will tell you what it means and what can be done.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 15, 2009 | Mitsubishi WT-42311 42" Rear Projection...
My wt-42311 shuts off then comes back on after a few minutes.
ur power board ic inverter is about to die.
It will die sooner or later,when it dead.U get no
power period,must replace the board.
Aug 23, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi wt-42311 picture is to long.
Its all in you remote.you need to turn off cable box and then tv. then turn on box from remote and then tv. I have the same problem when someone in the house turns it on incorrectly. make sure you can see the network sign in corner of tv complete then you have it. you may need to do it a couple of times. tv off first then cable box. or tv on then cable . its been awhile since i had the problem
Mar 24, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi
have you tried using your remote control?
does it shuts off?
its something to do with the circiut board of your tv. if not its simply the power switch of the tv. that can be replaced bby repair man.
Jan 27, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Wont staon
have you tried using remote control?
the problem of your tv is the switch button. contact a repairman to replace tat for you.
if it presist is something to do with chipboard.
TV Doesn't stay on...
HI
base in your comments in your TV you have defective power oscillation circuit! and need to diagnose your TV with a qualified technician! now if you have knowlegde in electronic trouble shooting i can give you the method to fixed your TV. Thanks in Advance!!!
Nov 15, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi wt-42311 tv wont stay on
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 hd tv has "pulsating" problem
A Mits qualified tech and/or warranty repair facility near you should be consulted.Involve Mits in the repair loop for accurate info.
Sep 26, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
191 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
