Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Fuse WHERE IS THE MASTER FUSE
  • 10,865 Answers
Hello. Under the hood in the battery compartment.
Posted on Jul 06, 2010
Where is master fuse box located ??
Bentleys do not have a master fuse box as such. There are several fuse boxes both major and minor distributed around the car and countless fuses. The owner's manual only covers the more obvious fuses,many more are involved in the car. Without knowing which system has failed it is impossible to give locations.This is the primary boxc391b666-c2e3-4471-8a51-d47ee3affbfd.jpg
May 10, 2015 | 2000 Bentley Azure
I cant find the relay for my ,05mazda MPV for power windows
There is a 30 amp P.WND fuse in the fuse box-doesn't say which fuse box, but it is position #25 in that fuse box. When the key is turned to on, this fuse should have power. If it has power, then the hot wire from it goes into the power window main switch- the driver's master switch. If the switch has power to it (key on), then suspect the master switch.
Dec 28, 2014 | 2005 Mazda MPV
Where is the master fuse ?
well there really is no master fuse but if your trying to cut power to the ecu which is like the brain of the car you just look in your handbook under fuses which will tell you or sometime's if their nice it will be on the back of the fuse panel!! goood luck
Mar 07, 2013 | Cars & Trucks
Cant find fuse for power windows?
According with the Explorer Owner Guide, I suggest...
1. Check for power on the Light Blue/Black (LB/BK) wire at the master window switch.
2. Check for a good ground to the master window switch on the Black (BK) wire. This wire provides the ground circuit for all of the window motors.
If both of these are good you probably have a bad master switch(drivers master switch).
The Light Blue/Black (LB/BK) wire gets its power supply from the accessory delay relay in the Central Junction Box (CJB) located under the instrument panel. The Generic Electronic Module (GEM) controls activation of the accessory delay relay. Fuse 2.17 is a 15 amp fuse in the CJB which supplies power to the relay. Fuse F1.6 is a 60 amp fuse in Battery Junction Box (BJB) which also supplies power to the accessory delay relay. G400(ground) is located at the driver side rear of the vehicle near the tail light assembly. This connection provides a ground for the master window switch (click image for zoom).
For additional details, i suggest try to look and obtain this 2002 Explorer Owner Guide 6th Printing (English).
Hope helps.
Oct 12, 2011 | 2002 Ford Explorer
Where is the master fuse located
The master fuse is location in the fuse box under the hood. It is conneted from the battery on one side and the alternator on the other side. There are two nuts on the passenger side that hold the two wires and fuse. You may have to pull up the whole fuse box. There are two plastic clips that hold it to the rade support.
Sep 23, 2011 | 2000 Ford Taurus
I need to find the fuse location for the electic window controls on the driver side, which is the master control
i dont thing is a fuse for that, all doors are contolled by a relay.and if it was a fuse would be 1 fuse for all doors too. maybe you have problem with your master contol. Thanks
Mar 28, 2011 | Oldsmobile Delta 88 Cars & Trucks
I think I blew a fuse in my 1997 Isuzu Trooper. My ABS light came on as well as my power windows stopped working, and my rear defroster as well as mirrior defroster. This has happended in the past and a...
Locate your fuse box/panel, there should be a listing of all fuses on teh fuse box cover or in the owners manual. I would visually inspect one fuse at a time pulling out and verifying all are good one by one as well as replacing the master fuse. I hope this helps you.
Oct 27, 2009 | 1997 Isuzu Trooper
Electric windows do not work
You have 2 fuse feeds in battery junction box under hood.Fuse 6(60amp) and fuse 62(30amp) and one fuse in the interior fuse panel no. 17(15amp).
How the system works is fuse 6 feeds fuse 62 which feeds the switch side of the accessory delay relay which is located in the interior fuse panel. Fuse 17 feeds the coil side of the relay and the instrument cluster micro-processor grounds the coil side of the relay.
When coil side of relay is grounded it creates a magnetic field which pulls the switch side closed which then lets power flow to the master window switch on the LB/BK wire on pin 6. The ground for the master switch is G400 which is the BK wire on pin 2 and G400 is located in the left rear quarter panel next to the tail lamp assembly.
Hope this helps.
Apr 06, 2009 | 2004 Ford Explorer
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
71 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
