Question about HP Pavilion A730N (PJ510AA) PC Desktop
The monitor is blank
The only thing pop up is out of range:hd15
  • HP Master
  • 11,800 Answers
The resolution of the desktop is set too high - boot in Safe Mode and lower it.
Posted on Jul 06, 2010
Question about Computer Monitors A friend of mine was getting ready to throw away a monitor that he thought was junk, so I took it off his hands. It's a HP 24 inch LCD color monitor the model number is HP...
Your capacitors are damaged. You will need to check the capacitors (the most common fault) or alternately check for internal power supply.
The capacitors can be seen in the internal power module, once you open the case you will those little cylinders. Check for leaks and replace as necessary. Cost will range from 6 to 16 usd.
Feb 15, 2015 | HP Computers & Internet
I want to change my 15 pin vga cable to my monitor
There are two types of cable set up with VGA monitors. The newer ones have a cable that is detachable at both ends. In other words the cable can be unplugged from the monitor and the computer. These, of course are easily changed. They can be purchased at places like Best Buys,
CompUSA, TigerDirect.com. Below is a listing on Ebay for a replacement for about 8 dollars including shipping.
SVGA-VGA-HD15-/280624443642?pt=LH_DefaultDomain_0&hash=item41568530fa">
http://cgi.ebay.com/Male-to-Male-15ft-PC-Monitor-Cable-Cord-SVGA-VGA-HD15-/280624443642?pt=LH_DefaultDomain_0&hash=item41568530fa
If you have the type of cable that is permanantly mounted to the back of the monitor, then you would have an extensive operation to replace the cable and it would likely be more expensive than the monitor was in the first place to replace it.
Hope this helps,
Best Regards,
Mark
Feb 03, 2011 | Computers & Internet
Analog out of range display on the screen
try the lcd monitor on another PC, if the same message pops out, your monitor needs reprogramming of its A/D board, bring it to a LG service center..
if it works fine on another PC, try to boot your PC on VGA mode..
May 10, 2010 | LG 22" FLATRON LCD Monitor
INPUT2: HD15
Seems to be some problem with your monitor not with your computer. Check monitor settings.
Oct 01, 2008 | Computers & Internet
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
HOW TO CONNECT MY PROJECTOR TO MY LAPTOP?
I have hp laptop with hdmi & vga, sharper image projector with rca connector what do I need to connect these two
Dec 22, 2007 | Philips cBright XG2 Multimedia Projector
No Display
for the HD15 connection you need to set your TV to PC mode
the only thing I can think that you may be doing wrong is that you need to "ACTIVATE" the external outputs on the laptop,as they are not on by default.
To switch video output mode  LCD / CRT (monitor/PC mode) /TV mode plus some dual modes LCD + CRT / LCD + TV
I have found that the overlays used for video playback do not work in the dual modes,  (and I have found that CRT monitor mode is best for connecting to a large TV)
so switch your TV to PC input,  connect your HD15 cable and SWITCH output mode on your laptop (usually Fn F5) press until you get an output,
you will also need to connect audio, so get a phono -> 3.5mm jack plug and plug that in also, and you are ready to rock and roll
Oct 11, 2007 | Hitachi CMP205SXU 25 in. Plasma Television
HP Pavilion A730N (PJ510AA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
