Question about Microwave Ovens
I have a Kenmore Model 665 Elite Dishwasher. I recently had to replace the main fuse. In working on the unit I noticed a thermal vent actuator switch in the vent assembly. What does this actuator do? The only thing I can figure is that it sends a signal to open the soap dispenser based on vent temperature.
  • bobgregg29 Jul 06, 2010
    Thanks for your explanation
  • 2,272 Answers
Each time you open and close the door, the actuator switch is working. When the plastic piece breaks off or the actuator switch stops responding, it needs to be replaced.
The door will not detected as closed if the vent door switch gets faulty .
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 06, 2010
Where is the thermal fuse located at on kenmore microwave model 665
Depending on the total part number 665xxxxxx a replaceable fuse is located behind the control panel usuallyon the floor of the control cabinet.
on one specific model "not yours" to check out the fuse locations a part number 309796 was found and I've included an image. Values of the fuses change based on specific models.
A typical location is included in the following image.
26047724-i5ybdsgcpm55v0g4hkv2rsri-5-2.jpg During previous repairs the fuse holder has failed and has required repair in addition to the fuse being replaced. This work needs to be accomplished by a qualified repair person. Even with power remove voltages remain because of stored engergy in the capacitors.
Hope this has been of help?
Jan 10, 2016 | Kenmore Microwave Ovens
Samsung microwave not working
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 02, 2013 | Samsung Microwave Ovens
Wont turn on
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Oct 10, 2012 | Daewoo KOR6N9RR Microwave Oven
Won't run
Test the switchs door see diagram
Oct 10, 2012 | Frigidaire FMV156DC Microwave Oven
No power
Sep 27, 2012 | Kenmore 30 in. Microhood Combination
Replaced fuse still not working
Test too c.breaker and reset+power cord+transformer+capacitor+rectifier HV+Magnetron for open , or faulty. see the diagrams
Sep 24, 2012 | Sharp R-353 Microwave Oven
Kenmore microwave 911 41479791 no power?
Sep 24, 2012 | Microwave Ovens
Our Kenmore microwave started emitting odors and then quit
To figure out what is wrong with it, it will have to be removed from the wall, Then the top cover will have to be removed, then you can look for any swelled capacitors, burn marks on the circuit board or any shorted wires.
The power supply is most likely faulty . You can test the power with a voltmeter from power supply to main circuit board.
Oct 28, 2009 | Microwave Ovens
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
