Question about HP LaserJet 2840 All-In-One Printer
Loud Screeching noise when printing.
Sounds like it is in top right side, but I don't think its the scannner motor. Sounds like a polygon motor going bad or maybe a spun bearing in a fan.
  • Anonymous Apr 08, 2009
    very high pitch squealing noise when printer is spooling up
If i was you just phone HP and get it replaced, thats if its still in warrenty.
Posted on Apr 21, 2008
Screeching noise when starting
It sounds like the solenoid or starter may need to be replaced or both, which are usually sold together.
Oct 24, 2013 | 1A Auto Parts 1999 Oldsmobile Delta...
Sometimes get a loud screeching noise from the condenser fan motor. Also seems to be loudr than usual. Motor part no. is:S070. Can a "do it yourself" guy replace the unit?
If this is wall/window unit, you can do it but it can be tricky. the fan in window units usually has 2
shafts on either side , it drives fan for both the condenser and evaporator. You basically have to pull the top off, loosen set screw on both blades, remove some screws to move back condenser coil(gently, don't kink tubing) similar process on evap side. Then mount new fan motor, wire it in put fan blades back on in proper position, reassemble unit, test run on bench.
Jun 26, 2011 | Heating & Cooling
MON PHOTOCOPIEUR AFFICHE LE CODE ERREUR L 6 SUR LE PHOTOCOPIEUR SHARP AR-205 DIJITAL QUE DOIS-JE FAIRE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
Feb 09, 2011 | Sharp AR-M205 Copier
Tempstar a/c condenser screeching noise
Could be the fan motor's bearings. Try turning the fan by hand to see if spins freely or is tight. If it's tight you can try oiling it but that may not work for long.
May 30, 2010 | Heating & Cooling
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Squealing/Screeching Noises
well hi,i think it sounds like the belt,it will do it when clothes are wet,but as they dry it don,t do as bad. or dose it get worse when it runs for a while. either way it sounds like the belt.
May 30, 2009 | Dryers
Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
May 05, 2009 | Amcor A12000E Nanomax Portable Air...
Cadilliac diver side window won't go up
it sounds like the window motor is going out and you need to replace it. i would get it to a shop right away tomorow.
Dec 18, 2008 | 1996 Cadillac DeVille
When filling with the side fill pump makes loud screeching noise
Hi Tom. if the noise is a loud SCREECH that almost sounds like a wounded bird, you need to replace the water pump. The part is easy to replace with no tools and you can get one from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
Dec 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
HP LaserJet 2840 All-In-One Printer Logo
498 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
