Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Fridge is buzzing on and off and not cooling top or bottom
  • moneika_king Jul 19, 2010
    The compressor is running the fan has been replaced but the freezer of the bottom is not cooling.
    President:
  • 1,891 Answers
Sounds like the compressor trying to start . / this is a job for service tec. problem it probley the start relay on the compressor . or the comp itself .. mm
Posted on Jul 06, 2010
  • 833 Answers
SOURCE: dual cooling fridge feezer top part of fridge warmer than bottom
You're frosting up. Either the box is set too cold or you've got a moisture problem which requires a full defrost. The fan noise is the blades hitting ice. Leave the unit open and off for a day or more and then start with standard factory settings. Avoid open liquids and window shopping inside your fridge.
Posted on Feb 01, 2008
  • 958 Answers
SOURCE: not cooling on top
that's very odd...normal air flow is from top to bottom, could be the light is always on, a defective door switch. look at the light and gently close the door, observe the light, it should turn off before the door closes tight.
Posted on Feb 14, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Fridge not cooling
We will need to see if yours has the defrost timer or the adaptive defrost. Let me know if your model is the JSD2789GES. I have the manual we can work with. ..Sea Breeze
Posted on Jun 21, 2009
  • 553 Answers
SOURCE: Fridge wont cool.
Refrigerators draw air from the freezer to cool them. There are several possibilities. First check to see if you need to defrost the freezer, this can cause a blockage stopping the air to the refrigerator also make sure that there is nothing blocking the air flow in the refrigerator.
You can set the freezer colder and turn up the refrigerator setting dial.
If these don't work it could be the fan that is supposed to circulate the air to the refrigerator is not working. The door switch for the light often turns the fan off while the refrigerator door is open.
If the freezer is all the way up and items in the freezer aren't frozen hard then you most likely need you system recharged or there may be something wrong with the compressor.
Posted on Jun 06, 2010
heatman101
  • 43501 Answers
SOURCE: Problem with the Amana Easy
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 10, 2010
When we shut the fridge door a loud continuous humming noise comes from the fridge. This seems to be activated by the door light switch at the top. Thank you
There are 2 possibilities I can think of for the hum. When you activate that door switch it activates 2 fans and the compressor. There is one fan located on the compressor and one located in the vent system in the fridge. The second fan is used to circulate cool air evenly through the fridge. I would recommend holding your finger on the door switch and listen carefully whether the noise is coming from inside the back of the fridge or from the lower bottom. Lower bottom could indicate compressor cooling fan or compressor. They would need to be inspected. If it sounds more like the other fan mentioned above it would again need to be inspected. The compressor cooling fans can get stuck or become noisy due to bearing failure. The vent fan can get stuck or noisy but also in some cases if the defrost circuit is not working can chock up with ice and create a buzzing noise as the fan blades strike the ice.
Jan 13, 2017 | Refrigerators
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Fridge not cooling, freezer not freezing, buzzing sound
with any luck this is you overload and relay
it is the plug on the actual compressor, this is very easy to replace, if you replace it and it does exactly the same thing its your internal relay and your compressor is done....
Oct 02, 2009 | Maytag MTF2155GRW Top Freezer Refrigerator
Clicking, buzzing, compressor too hot, thawed out
Sounds like the compressor is in thermal overload. Let it cool down completely and meter the starting amperage on start to run. The compressor could be seized or it's windings could be shorted to ground (checking the resistance between the windings terminals on the compressor while unplugged will determine this.).
Jul 14, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Greetings! My Whirlpool 21 is not cooling on the bottom, but the fridge is OK. Art
I do not understand your question because your note says it is a top freezer, but the fridge is ok?
The bottom section IS the fridge on this type.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Frige and freezer are not cooling!!! Help
chances are the fan motor has quit have a tech replace it if this is not the problem it could be a sealed system issue or a defrost problem
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
HELP ME FRIDGE IS BUZZING AND LEAKING
could mean ice build-up on evaporator - buzzing could be fan jammed asgainst ice. remove back panel of freezer to check. this would usually affect fridge as well however
Apr 10, 2007 | Frigidaire FRS23R4A Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
148 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
