Question about Sony Handycam DCR-TRV22E Mini DV Digital Camcorder
The tape will not load properly. Error C32:23
    Sergeant:
    Champion:
  • 338 Answers
Your camera is telling you to clean the heads, get a tape cleaner ASP
Posted on Jul 06, 2010
I am trying to load a new roll of labeling tape into the Dymo Organizer 1610. But the tape doesn't advance properly into the front part of the machine that does the printing.
Before inserting the tape into the feed mechanism, bend the last 1/8 inch of the tape upward at a slight angle. This will insure that the tape feeds properly. I just learned this by trial and error.
Aug 03, 2011 | Office Equipment & Supplies
JVC GR D20 E
Usually when a device (or any device for that matter) spits a tape out, it usually means the tape isn't sitting properly inside. There could by some obstruction preventing the tape from going in properly. Check to see the tape is in it's regular form...it hasn't changed shape dramatically. Make sure no foreign objects (sticker...lint) are on the surface of the tape (on all sides) and inside the camcorder. Maybe the tape isn't being inserted properly (try inserting at proper angle) and do it gently. If it still doesn't work, it could be that the tape has malfunctioned or in the worst case scenerio, the camcorder loading mechanism has malfunctioned (meaning it needs to be serviced).
Dec 18, 2007 | Video Cameras
Doesn't play or record tapes. Get a C.30.41 error. Will load tape. Tried resetting.
dear
u need to rate me for that ..ok dude....
actuallythis error is related to Head assy. i.e, the (head)drum motor is not completing its fg in proper time. try to use cleaning tape 1 st and then play back your normal tape.
if the problem persists then u need to go to the near by service center as they will clean the head assy. manually.
Jul 01, 2009 | Sony Handycam HDR-HC3 HDV Digital...
Tape deck no longer plays large DVCpro tapes
the tape compartment elevator has switch senors that tell the machine what size tape is in..
does the tape load all the way.. you need to tell us
is there an error code ?
either the sensor or the reel motors the feed and uptake the tape,,
they ride on rails and slide into position to accomodate the tape side they could be having trouble moving, dirty, broken actuator
Apr 07, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
Tape End Sensor Error - UVW1800
these error codes point to possible problems with one or both reel motors.
Dec 11, 2008 | Sony Betacam SP Small Videocassette 30...
Problem loading tape
the tape may be the wrong sort for you particular camera or there could be falty wiring in the display box i suggest that you get a specialist to help this isn't really my cup of tea.
Jun 27, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
May 08, 2008 | Sony PVW-2800 VCR
My Panasonic NV-SD270 video player wont play or release a video cassette and shows the error message "F05". Does anyone know what this means? thanks Chris
when the loading mechanism have a trouble and did not thread the tape properly , the eject mode commands primarily coz the tape in sensor activated properly
Apr 29, 2008 | Televison & Video
Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
Oct 17, 2007 | Sony DSR-45 Mini DV VCR
SLV-660HV Will not load
If you removed the tape carriage assembly, gear timing is probably off, assuming it is gear driven. Being one tooth off will prevent things from working properly. Gears will often have a mark (like an arrow or dot) which must be lined up with each other, in a mode specified in manufacturer service literature. Another possibility is sensors. There are sensors (usually optical) which tell the logic when the tape is properly loaded. If one of these is broken, or otherwise non-functional, logic circuitry will go into error mode, and, in this case, eject tape & display an error code. Lastly, check your mode switch. This tells the logic what position the mechanicals are in (gears/levers/slides). Again, if this is awry, you will have an error condition.
Jun 04, 2007 | Sony SLV-660HF VHS VCR
Sony Handycam DCR-TRV22E Mini DV Digital Camcorder Logo
67 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
