Question about Apple iPod touch
How do I unlock my ipod it won't unlock . It was recently dropped in water by my nephew. It was working again today after I let it sit for about 2 weeks. I was able to turn it on and it lit up like it used to. It would not let me unlock and use it. It is an iPod touch.
  • 864 Answers
Did you forget the password or is it not allowing you to even put in a password. I will start with a how to reset the password. If this does not work please let me know by following up with a comment and i can instruct you where to go from here. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Posted on Aug 24, 2010
My mother in-law has a craftsman 1996 22 inch Lawn Mower, model number 917.377532. Just recently my 18 year old nephew had cleaned the carburetor and replaced the spark plug and primer bulb. It worked for...
how long has it been since it was running good? Todays gas goes bad very fast.
It may not be the Nephews mechanicals skills that is the problem.
Dec 03, 2012 | Garden
Iphone screen locked
try switching the phone off and on again
Jun 05, 2010 | Cell Phones
I need to sync my nano to my mac, not my nephew's PC!
Well, if your nephew's computer is a Windows, that means you will have to restore your ipod back to factory settings to get it to work with your computer. Open itunes to the main ipod page. It should tell you that a Windows ipod has been detected in itunes and you will need to restore your ipod in order for it to work with your computer. Click ok on that message, or if that message does not appear, click restore on the ipod page. Then it should tell you that all of your information will be deleted. Click ok if you have all of the music backed up and after it restores, it should be working normally.
Feb 19, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod
my nephew was thrown into a stock tank by his friends, he had his ipod in his pocket... also did not work.  I brought it home left in my car on the floorboard, for 2 very hot days. Then remembered it was still in the car... not sure if the heat from the sun helped, but couldn't hurt
Brought it inside noticed the charger plug-in area had built up corrosion, carefully cleaned it with a dry swab, thin rag, and made sure all the plating was free of corrosion... earphone input, etc
then I held down the play button (top) + select (middle) button till the apple appeared on the screen.
p.s. it's been awhile, it may also be the stop and play or stop and select. if at first you don't succeed, you know the rest.  trying all of these options should not harm the ipod...  proceed with caution.
Long story,short. It is still working today.
Sep 18, 2008 | Apple iPod nano
Ipod disabled
mine is doing the same thing "ipod is disabled try again in 60 minutes" idk what wrong but my ipod is only 2 weeks old.
Jul 06, 2008 | Apple iPod touch
IPod click wheel frozen
how do i unlock my ipod
Jun 05, 2008 | Apple iPod nano
Dropped in water
this happened to me for more then 3 seconds in water for the razor, turn off the phone, remove the battery and SIM card, let it sit in a dry place over night, and check again next day, it should be fully functional
Jan 01, 2008 | Motorola Mobility RAZR V3
Try to restart the Ipod.
Hold the select button and the menu at the same time until you see the screen go off.
If still does not work then try to enter disk mode and see if it works.
Disk Mode:
Reboot the ipod via Select and menu, right away hold the select and play button and hold until disk mode comes on. Does the wheel work?
If still does not work then reboot the ipod again and let it reboot normal to go back in apple firmware. If all buttons are working and none of the above works, I would assume it is not software related.
Nov 12, 2007 | Apple 20gb Ipod Mp3 Player With Click...
How do I Unlock Ipod screen if I forgot the 4 digit password?
From the link Noggin posted I was able to unlock my iPod: Here is some brief explanation: 1. Connect iPod to your computer, it have to be the same one you used the first time to sync your iPod. 2. open iTunes. 3. disconnect iPod from the computer 4. It should no longer be locked. 5. Change the 4 digit passcode If this doesn't work you will have to restore it back to factory settings: 1. Make a backup, the restore process will delete all your songs and files! 2. Connect your iPod to the computer and wait until your itunes detects it. 3. Click the restore button and follow the instructions. * I have never done the restore process so I cannot help you further...
Jul 01, 2007 | Apple iPod nano
Apple iPod touch Logo
63 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
