Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Need to know the wattage Have just bought a new generator
  • 4,793 Answers
Use a triangle.amps/volts over watts.
110 x 15
so by doing your sums the answer would be???
1650.......
Posted on Jul 06, 2010
Wireing diagram for 115/240
Gotta know the brand and wattage first. You may find what you need in the generator's website
Jan 01, 2016 | Electrical Supplies
I cannot keep this weed wacker running.
i do not think this is a voltage issue, this a wattage or power out is not enough power in watts to keep the weed eater running, you need to know what wattage the weed eater requires to run.
even though you have a generator that says it will run 3000watts, but in the generator only runs at 1500watts continuously running time until it runs out of gas.
know lets say your generate say 2000watts, that means you are only going to get 1000watts continuously unit you run out of gas.
Oct 05, 2015 | Electrical Supplies
Electricity current eratic
The output of the generator is listed as a constant voltage and a maximum current or wattage - that could also be thought of as capacity.
Typically, it would be rated for 120 or 120/240 volts for generators sold in North America and the wattage could be as low as 3,000 - 5,000 to substantially more than that. If you were to look at the watts or amps while a connected light bulb were turned on, you would see the voltage stay at 120V, but the amps would go from 0 to .833 Amps - and the wattage from 0 to 100 (assuming a 100 W bulb). Next, connect a toaster - again the voltage stays at 120, but the amps and wattage would jump from .833A and 100W to 8 or 9 amps and 1100 watts. As soon as the toast was done - the amps and wattage would drop back to .833A and 100W. The same could hold true for a well pump or air conditioner that is connected to the generator.. these devices turn on and off automatically as determined by a pressure switch or thermostat. Seeing a wattage or current that fluctuates is normal as the amount of power needed from the generator changes as the devices turn on and off by them selves.
Also, it is not unusual for motor operated devices to draw 2 or 3 times as much amps or wattage during the first few seconds when starting as opposed to what it uses when running.
May 18, 2015 | Electrical Supplies
What faults can a change over switch caurse between the generator and the load
One consideration is how many circuits and how much total wattage is being used when the generator is in service.
"Gas Powered Generator GG2300 2300 Watts Surge 2000 Watts Continuous Output 10 Hours of Run Time at Full ."
This is a relatively small generator with 2000 watts output, so the problem may be that the generator can not handle the wattage demand. You can get a pretty good estimate of the wattage demand by adding up the wattage of everything , all lights, appliances, etc that's being powered by the generator. If the total wattage is greater than the output of the generator (2000 watts) then the generator is too small.
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
Power loss
950 watt is very small. Most electrical appliances need 1000watt to operate so if the vacuum cleaner is 1000watt then the gen set will trip. Check the drill as it is possibly 850watt which the gen set can handle. It all has to do with the wattage of the equipment you intend to run from the gen set
May 09, 2013 | Winco 5500 Watt TriFuel Power System w/...
New generator bought on 2008 used for the first time 10/11, ran for about an hour and a half and stopped out putting any wattage, engine runs great...
This could be anything from a blown fuse to a shorted circuit. My best recommendation would be to have an electrician look at the generator.
Nov 10, 2011 | Electrical Supplies
I have a kenmore refrig/freezer. Full load amp is 6.5 , 60 hz and 115 volts. I have a generator that will take 1100 watts with 1500 peak or surge watts. I heard that refrigerators use more electricity or...
The calulation of max wattage is going to be 750 watts at start up and be around 500 on normal running wattage after start up so a 1100 watt generator should be fine.
GENE
Sep 06, 2011 | Kenmore Refrigerators
The generator kicked the breaker of and was smoking and smelled like electrical
What type of load (electrical) was hooked up to this generation?? If the surge voltage and current was exceeded above the generator maximum for any length of time. There problems, it could be the regulator, insulation burnt off the windings.
I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This mean that the generator will deliver 7100 Watt (voltage times current) this is know as the power factor. The actual operating load would be 6800 Watts and I would even operator the generator at its peak wattage. Something in the neighborhood of 10--15% less the peak wattage. Therefore a good positive theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator would run all day.
Just remember Ohm's Law. Current plays a big factor in loading of a generator while the operation voltage is at 120 AC Volts. Example: electric motor; Now electric motor when starting will pull three time its operation current. Operating current for a 1/2 HP AC motor is 6 amperes but start this electric motor will require 18 amperes. This is one reason why they starting capacitors on smaller electric motors. Larger three phase electric motor can literal stop a generator cold...in its tracks. It put such a large demand on the generator it stops the engine powering the generator. I have seen crankshaft break because the generator could handle the heavy current load.
Remember, any time you are running a small gas powered generator. All ways figure what the load and surge current load will be before hooking up any generator. Normally this is figured in VA (volt/amps). Wish you lock. GB...stewbison
Sep 05, 2011 | Robin Subaru RGX7100 7100 Watt Gas...
What is 3250 wattage i am looking at a gaggia machine to buy and it says it is 3250 wattage will i need special electrity power thanks
Hello and Welcome to FixYa!
Please explain your query a bit more... What I understand is that you need to know what that 3250 W means. Actually this the power (approximately maximum) that can be generated using that equipment... Every electrical equipment consumes certain power e,g. Ceiling fan ~100W, Iron ~1000 e.t.c. You wouldn't need any special electricity power as such.....
Regards....
May 24, 2010 | Briggs & Stratton 3,250 Watt 6.5 Hp...
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
104 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
