Question about Casablanca Fan 74U9D Four Seasons® III Classic White Ceiling
I changed the light kit on a Casablanca fan and
I changed the light kit on a Casablanca Four Seasons fan and now the fan doesn't work.The lights kit works fine, but no fan now.
  • msullivan69 Jul 06, 2010
    Is there any reason why changing a light kit would cause the fan to stop working? All connections are tight and secure. It looks like it might be set up for a remote, but we don't have one. We just bought the house and there was no remote, just a wall mounted multi-speed switch.
  • 677 Answers
What to Do When Your Fan Doesn't Turn On
If your fan's not working at all, first check to be sure that its' getting power from the switch and from the breaker or fuse box.
Check to be sure that a fuse hasn't blown, or a breaker hasn't flipped, then look at the switch. Here's how:
tep #1. - . Turn off the power to the circuit your fan is on
Step #2. - Remover the switch cover plate, and unscrew the mounting screws that attach the switch to the electrical box.
Step #3. - Using a voltage tester, check the screw terminals on either side of the switch. They should not read as “hot” or charged. Once you've determined that you won't get a shock, pull the switch gently out of its box.
Step #4. - Unscrew the wires from their terminals. Straighten out the ends of these wires with a pair of needle nose pliers.
Step #5. - Twist the ends of the wires together, then screw a wire nut onto the end of this.
Step #6. - Turn the circuit back on, and observe the fan. If it starts moving, you'll need to replace the switch. You can buy a new one and re-install it easily, though you should make sure you have the power off before doing so! If the fan doesn't work again, your problem is either in the fixture itself, or the wiring. In that case, turn the power back off, replace the switch and cover plate, then check the fixture or call a repair person.
Posted on Jul 06, 2010
  • 2,272 Answers
Changing Light Bulbs
Be sure to turn power to the fan OFF at the wall switch or circuit breaker before changing light bulbs. other wise in some cases the fan switch gets short and fan stops working but lights work.
Also check out the fan motor and its connections.If they are not connected ot got loose while removing the fan lights and replacing them.Then due to loose motor connection fan will not start. For more troubleshooting:-- 1)Check main circuit fuses and breakers if your fan will not start. If your fan will not operate at any speed, you may need to replace the pull-chain switch assembly or PCB assembly. 2)Check for loose light fixture screws, glass shade screws, or motor housing screws if your fan is noisy. Tighten if necessary. Check for loose light bulbs and tighten if necessary. Check the canopy and switch housing for any loose wire nuts.
3)
Run your fan at high speed for a couple days to break it in if the fan is unable to run on low speed. If your fan will not reverse, you may have a defective reverse switch or capacitor and will need to replace the reverse switch assembly, PCB assembly or the motor unit. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
I have a Casablanca slumber three delta ii that I want to get a light fixture to fit. Can I use a Hunter, or are there certain ones I need to use?
You have to use the bottom plate to attach the light kit to so whatever you get ,you have to be able to screw the two screws back on the fan. I have some older Casablanca light kits that will work without the bottom cap. fanman9952@aol.com
May 13, 2015 | Casablanca Fan Dryers
Fan working but light won't turn off from remote
Call Casablanca @ 1-800-715-0393. It could be a bad light kit ( which can be replaced) or bad receiver.
Jun 01, 2014 | Casablanca Fan 3245T Ceiling
Lights went out casablanca fan
I never saw a Four Seasons fan with an Intel touch control and I've been in the fan business for over 20 years. What is the actual model #?
Feb 14, 2014 | Dryers
Need glass cover (case) for casablanca 652t
call Casablanca @ 1800-715-0393
Apr 18, 2013 | Dryers
Finding a light kit for a casablanca 652T fan
That's an old model so I don't know without seeing a pic for sure. If it has three screws on the bottom plate,you have to use an older Casa. light kit or almost any Bowl light should work. fanman9952@aol.com
Mar 27, 2013 | Dryers
We are installing a lighting fixture on our Casablanca 4944D Concentra. We can get current across the various wires, but can not get the light to turn on. The colors of the wires are blue, black, red,...
On ceiling fans, the blue wire is designated for the accessory light kit. If you are using the Casablanca kit, it should be wired with a matching plug that just, well, plugs into the fan.
If you are adding another brand of light kit, you only need to connect the blue wire (hot/common) to the black wire of the light being attached, and the white (neutral) to the white wire of the light being attached.
Your fan will not have a pull chain/switch for the light attachment, as that is normally supplied pre-wired and installed in the light accessory.
If in doubt about about the wiring, contact Casablanca for a manual showing what light kits are acceptable for adding onto your particular fan model.
Also, please turn off the power before connecting the light kit to the fan.
Hope that helps and best regards!
Jul 31, 2009 | Casablanca Fan 4944D Concentra Antique...
Panama 5 12444T
try to replaced the dimer switch with new one.
Jan 19, 2008 | Casablanca Fan 74U9D Four Seasons® III...
Ceiling Fan broken
clean and grease the fan check the black cap to see if it is not fauly if it is replace it.if that does not work the ammeture is faulty time to buy a new fan good luck
Apr 27, 2007 | Casablanca Fan Bel Air 3811T Ceiling
Casablanca Fan 74U9D Four Seasons® III Classic White Ceiling Logo
81 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
