Question about Kenmore 80012 Microwave Oven
My microwave is not heating up.
Everything else is working fine except I have no heat. I tried a mugf of water and ran it for 5 minutes and my water was still tap temp. What could be the problem and can I fix it easily?
Brian
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./.,
Posted on Mar 27, 2011
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
GE JVM 2050BH001 does not heat but everything else works
hey! you told that everything working in your microwave oven! inside the microwave oven! transformer only producing heat! that transformer only fault in your oven! try to repair or change the transformer!!!!!!!
Sep 29, 2008 | GE JVM2050 Microwave Oven
Everything works...Except for actually heating the food
It has a bad magnetron. This is the tube that provides the microwaves to heat the food. Not too easy to replace yourself but it can be done. Cost of magnetron is probably less than $50 or $60.
Dec 14, 2007 | Frigidaire PLMV168 Microwave Oven
Kenmore 80012 Microwave Oven Logo
101 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
