Question about Honeywell Heating & Cooling
I have a dayton furnace with a honeywell vr8440p-2088 gas control. The ignition works fine but the problem is I am getting no gas it seems to light the pilot. I checked the orifices at the end of the pilot gas tube and could see light thru it so it was not blocked. Could this mean I would need to replace the gas valve completely? Any help appreciated pelogius@nethere.com
Actually, after exhaustive troubleshooting and testing, all testing told me the gas valve was defective. I then replaced it. Problem was still there. I then took a shot for what it was worth and went down to purchase a new thermocouple to sense the presence of a flame. The salesman told me to remove the pilot flame tube and make sure it is not clogged. I removed it and sure enough the end was completely clogged. After cleaning it I was off and running again. So it just goes to show you that manuals don't always present troubleshooting in an exact order of importance.
I called the salesman back and thanked him.
Pelogius
Posted on May 23, 2008
I had the same problem with the same honeywell vr8440p2088 gas controler.  I found out the nob to turn on the pilot was broken.  If you can pull the knob off it is broken.  The knob has two small teeth on it to keep the pilot and gas open.  good look finding a replacment knob as the part is not made anymore.  But there is a relacement part for it.  it just costs about 250.00.
Relay keeps clicking and furnace will not start
try turning off the power to the furnace, wait about 10 to 15 minutes, then turn the power on, it might work, if not, the relay is bad
Oct 29, 2014 | Dayton Gas Furnace Heater
Replacing Goodman Furnace B18099-26 with ICM286 fails
decouple the output of the pcb ,put a 10-100nf between the two connectors
Nov 06, 2013 | ICM286 Furnace Control Board
I have a Dayton gas furnace FG8B07512MU12A. It has a new control board and worked fine for the last 6 months. Now when the fan goes on the air put out is cool not warm. The card shows a slow blinking...
Is the manual gas valve open, either plumbed or on gas valve? It may sound dumb, but it happens. Are the wires connected to the gas flow solenoid securely?
When the heat call initiates heat cycle, can you observe the ignitor? If it tries to ignite, is there gas entering the burner? How clean is the gas orifice? If the orifice is plugged, best to simply replace it.
Dec 18, 2011 | Dayton Gas Furnace Heater
I have a gas furnace with electronic ignition. Can't find a brand name or model anywhere. Intermitently the thermostat calls for heat, blower fan comes on, igniter comes on, and then either all the heating...
Hopefully someone with more experience will respond as well, but my experience with this type of furnace is that this is likely to be a clogged line or gas feeder control device. The behavior indicates that there not enough gas being presented to the unit. Unfortunately this is NOT a DIY type of repair. A licensed plumber should examine this unit. Gas units can be dangerous if not serviced properly. Please seek local assistance frmo a professional.
Dan
Nov 19, 2010 | Dayton Gas Furnace Heater
No ignition on dayton gas furnace. how hard is it to install new gas valve on a dayton furnace
not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
Oct 31, 2009 | Dayton Gas Furnace Heater
We have a dayton gas furnace model #3E463A. thought the control box was gone. got new one we furnace starts up the power goes on, fan starts no green pulsing light on control no ignition
When your furnace starts...the Ventor motor(exhaust fan) starts up....within a short time (seconds) the Pressure switch closes proving that the Fan is indeed running and the vent is not blocked...if this doesnt happen the furnace will not poweer the ignitor or fire at all....Check the vent pipe outside and look for obstructions or dirt on the screen inside the pipe...the condensate from the fuirnace may not be draining at all...due to plugged condensate drain lines...find this tube coming out of the furnace front...bottom of upper compartment usually , and pull it off the tap....if water starts coming out then your drain is plugged downstream of the furnace.
Oct 25, 2009 | Dayton Gas Furnace Heater
Fault Code on Dayton Gas Furnace
This happens when the furnaces tries to light to many times and doesnt succeed. If you stand in front of the furnace while it is coming on, you will be able to hear the problem. If its an electronic start, there will be a clicking sound, followed by the gas valve opening to start it. If it has a pilot light, make sure it is lit, then listen for the gas to come out, it will make a hissing sound. If no gas is coming out, first double check to see if the gas is turned on to the unit, if it is, then its possibly the gas valve. Oh, if it is electronic, and you hear gas, but dont see a glow inside the furnace, or no glow or gas, it could be the ignite. Hope this helps.
Jan 07, 2009 | Dayton Gas Furnace Heater
Dayton gas furnace
try cleaning the flame sensor and the burner , check out the pressure switch might be blocked in the tubes
Dec 07, 2008 | Dayton Gas Furnace Heater
Heating & Cooling Logo
483 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
