Question about Samsung TXM3297HF 32" TV
My tv won't turn on
I can't get my tv to turn on even though the red light is on in the on button. I tried manually and with my remote.
  • 3 Answers
It sounds like you have a blown fuse on the circuit board.The only way to tell is to take it apart,with the power off of course
Posted on Oct 13, 2010
Sky eye red light on but remote won't work
You are using the new remote and not the old Sky remote aren't you
Oct 12, 2017 | Televison & Video
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
I need to program my one for all remote to my zenith tv
Try the following steps: 1. Turn on the tv. 2. On the remote, press the "tv" button once. 3. Press and hold "set" button until the red light blinks twice. Release "set" 4. Using the remote's keypad, type in the digits 9-9-1. The red light should blink twice. 5. Point the remote at the tv and slowly alternate between pressing the "power" button and the "tv" button. Stop when the tv shuts off. 6. To save this code, press and release the "set" key. The light should blink twice. Your remote should be programed to your tv.
These steps came from the following link. If you have any problems, I suggest consulting the manual on the link:
http://www.hifi-remote.com/manuals/manual.shtml?URC-3021
I hope this helps! Sincerely, Der Strom
Apr 13, 2010 | One For All URC-3021 Remote Control
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
Its a tiny 42'' plasma tv which was working perfectly until my grandaughter dropped the remote control and the tv went off and now wont switch on even though the stand by light is on.It wont even turn on...
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
Thanks,
Chris
Boise LCD
www.BoiseLCD.com
Oct 08, 2009 | Televison & Video
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Samsung TXM3297HF 32" TV Logo
Jerry Greenberg
Jerry Greenberg
