Question about Scotsman Ice Machine, Cuber, 1930 lb. Unit, Head Only
My ice machine water runs all the time its like turning a hose on an sticking it in the drain shouldnt the water shut off when it fills up
2 Suggested Answers
  • 3074 Answers
SOURCE: Ice machine does not fill reservoir does not fill
Is there a water filter on the system? also the line might be clogged from the inlet to reservior
Posted on Jul 23, 2010
Why does my admiral washer fill and then drain as soon as it fills?
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
May 29, 2015 | Admiral Washing Machines
Lg top loader ie error message, fills ok, but water running out of bottom of machine
Hi IE means Inlet Error. The machine thinks that it is not filling (as a certain time has passed without reaching level it wants).
This makes sense if water is running out the bottom.
You will need to find the leak. Maybe the tub to pump hose, or the drain pump itself. Once you stop the leak and the machine can fill in the correct amount of time, you shouldnt see the IE error any longer.
Cheer
Jun 01, 2014 | LG WD-1045FH Front Load Washer
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Water fill and start
if the water valve is bad it will hum and no water will enter the washer,first thing is to see if it's a problem with the houseicon1.png water valve or the washer valve,shut off the water supply,reomve the water hoses from the back of washer,mark the hoses so they go back on the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses then you know the problem is just the washer,check the valve,look at the screens where the hoses connect to the valve,usually sediment gets in there and the valve on the washer has to be replaced,on some the screens can be removed and cleaned,also you say you have trouble with the lock,what's humming is it the lock or the valve,if you turn it to drain and spin will it run?you could have a bad door switch,if door doesn't latch washer won't run but most likely bad water valve
Jun 15, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
NFW7200TW hums and does not turn or fill with water
if it doesn't fill the water valve will hum,first thing is to see if it's a problem with the house water valve or the washer valve,shut off the water supply,reomve the water hoses from the back of washer,mark the hoses so they go back on the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses then you know the problem is just the washer,check the valve,look at the screens where the hoses connect to the valve,usually sediment gets in there and the valve on the washer has to be replaced,on some the screens can be removed and cleaned,also you say you have trouble with the lock,what's humming is it the lock or the valve,if you turn it to drain and spin will it run?you could have a bad door switch,if door doesn't latch washer won't run but most likely bad water valve
Drain pump won 't stop running
Nov 26, 2012 | LG WM-2277HW Front Load Washer
My washer water never shuts off water runs all the time had to turn off the valve to get washer from filling up
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
I hope this has helped you,
Gene
Aug 04, 2011 | Roper Washing Machines
Washing machine keeps filling and draining at the same time and wont fill enough to move on to the next cycle
The drain hose is too low and the water just runs right out...The highest point of the drain hose needs to be higher then the top of the washer before it goes back down into the drain. Also if the hose is sticking into water it can create a siphon which pulls the water out of the washer... make sure that you also have an air gap...
Heatman101
Mar 10, 2010 | Frigidaire FGX831C Top Load Stacked Washer...
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Scotsman Ice Machine, Cuber, 1930 lb. Unit, Head Only Logo
51 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
