Question about Motorola Mobility RAZR V3
Battery? The battery icon is flashing red when plugged in to the charger. It had a low battery earlier today, and shut itself off. I put it on to charge a while ago, and instead of the icon doing it's lines moving through the battery icon in green, it's not flashing at all, and it's red in color. I took it ( the battery ) out, and cleaned up the contacts. Still nothing but red. It's only 6 months old.
  • klkakj Apr 18, 2008
    I have the exact problem. in addition, changing batteries hasn't worked. could it be something malfunctioning w/ the phone? would really like to not have to buy another one. HELP!
    President:
  • 1,944 Answers
I am afraid that your battery has malfunctioned. You will need to buy a new one. But before buying a new battery try leaving the battery out of the phone overnight, then try chargnig again.
Posted on Apr 18, 2008
Batteries say fully charged on charger but only 1 red flashing light and the green
Hi okay if the red light is flashing , make sure you not in freewheel mode, it could be that the batteries are low , leave on charge for about 4 hours and test again.
Make sure the connector plug that fits from the frame to the handlebars is a good fit, this supplies power to the controller.
Regards
Dec 13, 2012 | Health & Beauty
Champ 3303i battery not charging
The battery or charger may be defective
Mar 29, 2017 | Cell Phones
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
Won't charge after the battery runs low.
that means your battery is flat so first boost the battery using universal charger or in other way charge you battery directly
Apr 08, 2017 | Sony Ericsson XPERIA X1 Smartphone
Earlier today my phone only charged for a few minutes off and on with the home charger. It flashed a red battery icon at...
dont worry , that is a normal problam , contact ur nearest service center.. or first verify ur betery charger (allways keep orginal betery charger.)
May 11, 2009 | Motorola Mobility RAZR V3
Motorola Razor V3 wont charge
Your Charger Port On Your Phone May Be Loose or Begining To Have A Break in The Wire, Seek A Phone Technician If You Do Not Have An Advanced Understanding Of Phone Circutry
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Battery/charger problem
Is your charger plugged into a power strip?  Try plugging it into the wall instead.  It worked for me.  It just blinked a few times then it began charging!
Oct 14, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Motorola Mobility RAZR V3 Logo
466 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
