Question about Whirlpool ACE244XS Air Conditioner
I need to know how to put freon in a ace244xs air conditioner can you help me
  • 6,927 Answers
You will need what they call a saddle valve.And a charge hose,and freon,most likely r 22.
Posted on Jul 06, 2010
Where do i put the freon in the zenith ZW6500R
Your uncertainty suggests this task is best left to a professional.
Aug 14, 2014 | Zenith ZW6500R 6,000 BTU WINDOW AIR...
How do I get the filter out of my heat pump?
Is this a window unit? If it is then its right behind the front cover between the cover adn the coils behind it. If its not there then you can by one at the hardware store .. clean the coils before you install is . you can do that by vacuming it with the house vacume or a sho vac if you have one.. Hope this helps let me know Jon
Aug 03, 2011 | Whirlpool ACE244XS Air Conditioner
@gmail.comshould i need to put more freon in this air conditioner?
The only time you have to add freon is if you have a leak in the refrigeration system. Check and make sure all your coils are clean and the filter is clean. If its a cleaning issue these things will seem like its low on freon but is not just needs some love.let me know ok
Jul 23, 2011 | Maytag NMPEB08F2A Air Conditioner
My plug on my unit needs to be changed, if i change it will my unit still work
Why wouldn't it work?
You remove one plug & replace it
with the same thing,what's the problem?
Jul 14, 2011 | Whirlpool ACE244XS Air Conditioner
Need an online manual for a whirlpool ac/heat window unit
Manual get it from:
www.devicemanuals.com/guide/Air%20Conditioner/Whirlpool/Whirlpool-ACE244XS-Air-conditioner-User's-Guide-TWpnM01EWT.h
Dec 29, 2010 | Whirlpool ACE244XS Air Conditioner
Water builds up in pan and theres no hole for it to come out of.. i have it sloping downwards. why is that?
The slinger blade (condenser blade) picks up water in the bottom and that helps cool off the freon. It is a built-in design. If water is coming inside the house tilt the ac downwards towards the backside so that the water can drip outside.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 25, 2010 | Whirlpool ACE244XS Air Conditioner
Fan is hitting sides and makine a rubbing noise
The fan pulley mat be damaged if no one played with the fan blades or dropped the unit or even it may be twisted over time if was not installed properly. You may be able to replace the pulley if the shaft not bend...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Whirlpool ACE244XS Air Conditioner
Air condition want cut off automatic
Hello, It sounds like your unit is going into defrost mode. Heat pumps struggle below 35 degrees F. Make sure the coils are clean so the unit will work at peak performance. They do make a heat strip to put in these units to help with cold temperatures. If you need more help just ask. Good luck.
Jan 23, 2009 | Whirlpool ACE244XS Air Conditioner
Whirlpool ACE244XS air conditioner blows out cool air when on hea
Due to Defective Thermostate Switch Try to Replace, will be ok
Nov 18, 2008 | Whirlpool ACE244XS Air Conditioner
Whirlpool Heat and Air Window Unit ACE184XRO- freezing up
This is only low freon. If the bottom coils freezes and frost over, you don't have enough freon to travel as liquid back to the compressor and boils right there and past this only cool gas .I'll advise you to get this fixed before you loose a compressor due to locking up by not cooling the compressor properly. Get in touch with an Ac man. this should only cost around $100:00
Sep 05, 2008 | Whirlpool ACE244XS Air Conditioner
Whirlpool ACE244XS Air Conditioner Logo
98 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
