Hi, I have an Armstrong A/C that blows cool air when the outside temperature is around 75 even up to 77. When it goes hotter then it blows just air. Is there a setting that needs to be changed in order to get cool air when outside temp is greater than 80 ? or I should get a technician to check the A/C Thanks
  • 456 Answers
It could be that the unit needs to be cleaned, it could
be that the compressor is tripping on an internal overload because the internal part of the compressor
is surrounded by high ambint air. It does not sound like a freon isssue.
Posted on Jul 06, 2010
What are the operating pressures on an Armstrong Concept 10 scua24 A/C
Didn't help ya huh Wayne?? We are in the temperature control businesses, temperature is what's important, not pressure. The hotter something is the more pressure it has. On a satisfied home, I will say 75 degrees, your evaporator coil should be around 40 degrees. 40 degrees with r22 is about 65 psi. 40 degrees with 410 is about 125 psi. Head pressure, your condenser temperature, will vary depending on the time of day. The hotter the temperature, the higher the pressure. R22, 200-225-240...R410a, 300-325-350. Keep in mind, the hotter the house, the higher the pressure. Hope this helps!!
Jul 08, 2017 | Heating & Cooling
Replaced a starter capicator, now it just bloweswarm air
On hot day your unit may not cool enough. Make sure that outside unit is clean, filter inside should be clean. If all above is good your unit may be low on Freon.
Aug 11, 2014 | Dometic Heating & Cooling
I have a Honeywell RTH230 thermostat. Ive read the manual top to bottom and have set the temperature to 70 degrees and followed all the directions. But my home is still almost 85 degrees, and even hotter...
i am assuming the unit is coming on and all... there could be an issue with the refrigerant in the system such as a leak.. need to make sure the indoor fan is coming on and also that the outside unit is coming on..there are 2 copper lines at outside unit that are refrigerant lines the larger one should be cool and the small line should be warm.. there also should be hot air blowing out of the outside unit... if this is not happening you have a problem with either the freon has leaked or the compressor may not be coming on inside the outside unit \
Jul 20, 2011 | Honeywell Programmable Thermostat Heater
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
I've just moved into a home with an existing Armstrong Concept 10 A/C unit that's at least 15 years old. When I left for a 2-week vacation, the unit was working great. I set the thermostat to 77 to save...
Hello 93 The compressor caused the breaker to trip.A weak capasitor or burnt wire is a common cause.It sounds like the compressor is NOT on even though the fan is.It may need a new wire or maybe a HARD START kit to help restore operation.Call for help.HS kits are not expensive.NO damage results from leaving it on, the problem would have happened anyway even if you went on vacation or not.The curcit breaker stopped it.Its worth fixing.
Aug 30, 2010 | Heating & Cooling
A/c works fine in the morning, blows out vents at 55* - 59*. later in the day, and as it gets hotter outside, a/c blows hot air. What's up?
could be slightly low on charge-or cooling fan is not working-as the temp outside goes up the ac needs to be more efficent to blow cold air--and really 55 is not that cold--depending on outside conditions should be able to blow at low to mid 40 s
Aug 16, 2010 | 2003 Ford F250 Super Duty Crew Cab
My ac unit will not go below 77 degrees. It quit working about 1.5 weeks ago, and I had a service technican come and look at it. He replaced the capacitor and the unit started back up and would cool to...
Hi, It sounds to me like you have covered all of the basis. The evaporator coil should be clean if you keep your filter clean and the condensation is showing that it is cooling properly. Normally, when the temperature increases outside, you will loose as much as 35% of your units efficency as it it working very hard. 77 degrees is very good temperature if the outdoor temperature is in the triple digits or a little less. It may be that your thermostat is off just a little also. If you clean your coils and keep it up like he said, that is great! I wish more people would do this. You should have a 18 to 25 degree temperature difference between the supply air from you vents and the return air at your filter. Example, if your supply air is 56 degrees, and the return air is 76 degrees, a 20 degree difference or TD, that is excellent. You can check this with a thermometer. I live in Northern Ca and it gets up to 116 degrees here in Redding!! We are lucky to have it 80 degrees in our home, no kidding!!. If you are unhappy, call this tech about it and see what he says. Your indoor coil is fine if you have no ice and I know you keep your filter clean. If you lost a capacitor again, you would have no cooling. Like I say, keep a eye on it, it could be the stat not accurate. Check the supply at the vents and filter to see what you have. If its lower then 18 degrees or higher then 25, you have a problem. If you are in the triple digits, this will cause this. I wish you the best and keep up the good work on that unit! That' great! Please keep me posted and please be kind when rating me as I know you will. Let me know the out come.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 05, 2010 | Heating & Cooling
Why would cool air be blowing out of my central ac unit condensor that sits outside? The other unit I have next to it blows out warm air and responds well to thermostat changes. The unit blowing cool air...
It probably has a low refrigerant charge. The air coming out of the outside unit should be warmer than the outdoor temperature when in the cooling mode and if it's a heat pump it should be colder than the outdoor temperature in the the heating mode. Check the big line going to the unit, it should be somewhere around the 40 F range and the small line should be hot.
May 23, 2010 | Goodman CKL24AR24 Air Conditioner
I just had a new a/c - heat pump installed on my 5th wheel. The a/c works well but when I turn on the heat pump it seems to blow air about the same temperature as inside the coach. I seem to hear the...
Hi; I hope You called a company that will honor any warranty on the heatpump. Sounds to Me like I would contact the original installer for more help or free replacement.Also at 55 or 75 degrees outside The heatpump should be providing toasty air. Only at close to freezing temps will You get a reduction in warm air and then the heat strips will help out then also check to see if the unit has outside air dampers and make sure they are closed..alpharome416
Feb 23, 2010 | Dometic Rooftop RV Air Conditioner
Can not get temp below 77
Is the thermostat set up for automatic change over from heat to cool? If so, the heat is probably set for 75, you will need to lower the heat setting in order to Lower the cooling. the stat won't let these settings with in 2 degrees of each other so the heating and cooling don't fight each other.
Aug 25, 2009 | Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
