Question about Brinkmann 810-2300-B Grill
I need to replace the battery in a Brinkman 8402 gas grill. Where is it and how do I get to it
  • 63 Answers
SOURCE: Igniter problem
right in front where the red botton pushs in to light! grab the ring around that and un screw it!
Posted on Apr 05, 2009
  • 10865 Answers
SOURCE: the gas flow cannot be raised and a slight breeze puts out the fl
The new gas grills have a safety device built into the gas hose that can cause this problem until you get familiar with it. The flame on a gas grill should be blue. If you have a yellow flame it could be caused by a couple of different problems. First of all the burner might be worn out. If you have an older grill then you should inspect the burner to make sure that there are no cracks or holes and that all the burner holes are the same size. If you have a newer grill or burner, or your burner appears to be fine then the problem might be with the regulator. The regulator is a round metal object near the connector to your gas supply. Sometimes regulators get stuck. This can reduce the gas flow, make a yellow flame and keep your grill from getting hot. To solve a stuck regulator, turn off the fuel supply to your grill. Disconnect the main connector and open the grills control value. This will eliminate any pressure on the regulator. Sometimes this will reset the regulator, but sometimes they stay stuck. Take a small hard object like the handle of a screwdriver and give the regulator a gentle tap. Now you can reconnect everything and see how your grill works now. If you still have a yellow flame your propane tank might be low, the regulator may need replacing or you could have a blockage in the venturi tubes. So check your fuel level by pouring hot, not boiling water down the side of the tank. Feel along the side where you poured the water. The propane level is where the tank feels cold. If you have plenty of fuel, locate the venturi tubes. The venturi tubes are located along fuel lines right behind the control valves. These allow air to mix with the fuel before reaching the burners so they have a small open space. If that space is blocked it will restrict the fuel flow to the burner. Make sure it is clear of obstruction. If you have done all this and still have a yellow flame you may need to look at replacing
Posted on May 29, 2009
  • 433 Answers
SOURCE: i need instructions for brinkman smoker grill how
I have a Weber Smoky Mountain which is similar to the Brinkman. I learned how to smoke by going to the VIRTUAL BULLET website. www.vertualwebberbullet.com. Also, going to the many forums on smoking helps.
Don't get upset if things don't work out the first time....keep on trying!
Hank
Posted on Jul 01, 2009
bbmcdonald
  • 14 Answers
SOURCE: new brinkman gas grill---side burner lights on
I have a few ideas that might help.
1). Before going to the expanse of new parts, your igniter AA battery MAY need replacing.
2). Your igniter wires might be loose. Remove the battery and check junction box found behind the Control Panel and connect any loose wires.
3). Check that the end of each of your main burner tubes are properly located over the gas valve fitting.
4). There MAY be an obstruction over the main tubes not allowing the gas lines to access it properly.
5). If obstructions in the hose or regulatory assembly is suspected, it would be best to contact Brinkmann directly at 800-527-0717
Posted on May 30, 2010
  • 4736 Answers
SOURCE: Brinkman gas grill won't start.
Victor, are you sure you're getting gas to the burners after installing the new tank? You can try match lighting them to make sure. But, I suspect, that it's the installation of the new tank, that's causing the problem.
To test my theory, tune the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Ope the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, try lighting the burner that's farthest from the tank first and turn it to high. Did the burner light and does the flame height look correct? If so, light the remaining 3 main burners the same way. Did those burners light and the flame heights looks correct? If, so you solved the problem. Remember to always turn the tank valve ON VERY, VERY SLOWLY.
Hope this helped you solve the problem. Happy Grilling.
Posted on Jun 01, 2011
Have brand new 810-3330-s brinkman grill main igniter is receiving no gas, is there a screw to adjust flame?
BEWARE: DO NOT TRY SUCH HAZARDOUS TRICKS YOURSELF AS LOCATING A SCREW TO ADJUST GAS PRESSURE. CONTACT THE DEALER OR AUTHORIZED CUSTOMER CARE.
Mar 29, 2014 | Brinkmann Brinkman Barbecue Grill Gas...
Looking for a brinkmann 810-3200G replacement burner
Unfortunately, your model grill has been discontinued by Brinkman. The burner you need, Part # 19810-3200-G is no longer available and there is no substitution.. Neither from Brinkman or other grill part sources. In fact, the only 2 parts available from Brinkman for you grill are an ignitor button & cooking grates.
I'm sorry, I wish I had better news for you. Thanks for choosing FixYa.
Jul 27, 2011 | Brinkmann Grill King Deluxe 810 3200-0
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
BOUGHT A BRINKMANN 2545 GRILL LAST NIGHT. WE HAVE IT ATTACHED TO GAS LINE COMING FROM HOUSE. GRILL WILL LIGHT BUT IT IS A LITTLR FLAME AND THE OTHER BURNERS WILL NOT LIGHT?
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
I have a new Brinkman grill and can only get a low flame and very little heat.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 17, 2010 | Brinkmann 810-2300-B Grill
I need instruction on how to put together model 8300 proseries Brinkman
Click on this Brinkman link for the manual you need. Scroll down to the 6th Brinkman model listed to find your model and click on it. You can then download this adobe file and print it up on your computer for free.
http://www.brinkmann.net/Customer%20Service/OwnersList.aspx?category=Gas+Grills
Have fun assembling it!
May 15, 2010 | Grilling
Instructions on how to put a brinkman gas grill
It might be best to just contact Brinkmann's Customer Service Department first. They should be able to either send you a Manual with snail mail OR point you to a link where you can download a copy of the instructions needed. Good Luck!
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Jun 27, 2009 | Brinkmann Stainless Steel All-In-One Gas...
New brinkman gas grill---side burner lights on ignition control but main burners do not light with ignition control---am able to match light the main burners----any ideas anybody
Clean or replace the main igniter. The backs corrode and need to be cleaned or replaced. Home Depot carry replacement parts.
Apr 25, 2009 | Grilling
Igniter problem
Apr 04, 2009 | Brinkmann 810-2300-B Grill
Brinkmann 810-2300-B Grill Logo
725 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
