Question about Dirt Devil Featherlight Bagless Upright Vacuum
Dirt Devil M088600 roller doesn't spin, no suction...
I bought this vacuum used, but it worked fine. The only problem was it made my house smell like dog, since the people who sold me the vacuum had 2 dogs and had vacuumed up a lot of dog fur. So I took the canister out and rinsed it, along with the long filter thing that goes inside the dirt canister, and now it doesn't work. It still powers up, but the roller doesn't spin and there doesn't seem to be any suction.
Help!
  • mommyx254 Sep 11, 2008
    I get suction through the attachment hoses but not through the bottom base. It worked fine for several months.
  • Anonymous Mar 25, 2014
    Also, for the first time had a hard time opening dirt canister but probably not related.
Check the belt
Posted on Jun 25, 2008
Dirt Devil easy lite makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi, it's Cindy from Crucial Vacuum.
From your description, it sounds like there may be something stuck in your roller or your filter may need cleaning or replacement. Refer to page 22 of your manual to remove your roller.
For optimal performance, your filter should be replaced every 3-6 months and washed every 1 month. Your filter is located under the dirt cup holder.
You can purchase direct your replacement filter from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f43-easy-lite-cyclonic-hepa-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 28, 2014 | Dirt Devil Easy Lite Quick Vacuum
Belt falls off Dirt Devil upright
I have a Hoover canister vacuum it works great.
I think you have the right idea. Good Luck!
May 15, 2017 | Vacuums
Belt keeps coming off
I believe there is something wrong with the roller, could be the barrings or the end caps are warped. Try this, take the roller out and with each hand on each end hold the roller and try to spin the roller with your thumb. If it does not spin freely the problem is the roller.
Nov 20, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dirt Devil- Brush not rotating on its own. No suction.
drive belt. take housing apart (draw a diagram so you can put it back together) take the broken belt to a vacuum repair shop to get the same one. mine cost 7$.
15 minutes work.
Jun 14, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Jul 30, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
DIrtDevil Ultra Handheld - No Suction & Brush not moving
take everything back out and make sure everything looks fine, then carefully put it back in do not force anything or it will bind up.
Dec 03, 2007 | Dirt Devil M08100RT Classic Handheld...
Vacuum problem
I bought a dirtdevil 8 years ago and it's still going. As long as the motor works then you have check to see if the brushroller turns. If not then check the roller belt (take the cover apart some have screws or lock tabs on bottom panel near wheels) If the suction is low then check the vac bag, also with bag off, turn on the vac to check if air comes thru.If not the inside tube is clogged(plastic bags, small objects, ect.)Also when you open the bottom panel to check the roller belt, check the flex pipe that sucks up to the vac bag(unclogg it).
Apr 02, 2007 | Dirt Devil M085805 Upright Vacuum
Dirt Devil Featherlight Bagless Upright Vacuum Logo
200 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
