Question about Onkyo TX-SR875 Receiver
Onkyo TX-SR875 AV receiver display not working
I have an Onkyo TX-SR875. The AV receiver display panel has gone. I replaced the 2 resistors referenced online. Once done, I powered the receiver back up and it turns off right away. Must be a short elsewhere?? I put the original resistors back in and it worked (receiver turned on). I powered off and unplugged to re-install the top cover. Once that was done, I powered on and it turned right off again. Not sure where to go from here...Any ideas?
robotek
  • 1512 Answers
SOURCE: Right front channel sometimes does not work
you have dry solder joints in the output stages to the front channel.-solution. resolder channel.... or dirty speaker protection relay contacts. can be determined by tapping the top of the protection very gently when fault occurring. solution. burnish contacts and treat with crc2-26
Posted on Dec 10, 2007
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Posted on Jun 02, 2008
  • 4234 Answers
SOURCE: Onkyo AV Receiver turning off - by its self.
The space you have provided should be enough. If this is a new unit and still under warranty, I would request warranty service. It sounds like the unit is entering protect mode. This may be due to heat or it could be because of a defect in the protect circuit. In any case, this should not happen that quickly.
Update this if not under warranty and I'll provide a list of diagnostic tests to help determine the problem.
Dan
Posted on Jan 16, 2009
SOURCE: Onkyo AV Receiver TX-SR 805 no display on the receiver
Finally one of us found the solution - thanks to cambrian
Please follow the link
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=579
BTW: My knowledge of electronics is very limited, but nevertheless I could fix the problem. I hope you can do it too.
Posted on Mar 12, 2009
  • 23 Answers
SOURCE: Video thru Onkyo TX-RS606 is only black&white
are you using HDMI cables or component. First I would try unplugging the composite and component video cables while the receiver is off. Plug them back in and turn it back on. If that does'nt work try setting the receiver to factory default and redo the settings. You can find how to reset to default in your user manual.
Posted on Apr 24, 2009
Onkyo TX-SR875 Everything works fine,just no main unit display? Any ideas?
R9304 or R9310 are broken, if no light in display. This are 10 ohm resistor sitting on the board behind the volum knob in front.
Jun 09, 2012 | Onkyo TX-SR875 Receiver
Display Panel Problem.... my Onkyo TX-SR805 AV receiver works properly except No Display on the front panel. I follow the instruction troubleshooting on the manual by resetting the unit but to no...
I follow the instruction troubleshooting on the manual by resetting the unit but to no avail. It's beyond warranty period.
please help, thank you
Sep 27, 2010 | Audio Players & Recorders
Onkyo tx-sr875 no sound through hdmi.
Hello, I suggest having your receiver serviced. Thank you, Onkyo USA
Apr 13, 2017 | Onkyo TX-SR875 Receiver
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Cannot get 7.1 on the onkyo tx-sr875
you can download a copy on the Onkyo website
Apr 21, 2009 | Onkyo TX-SR875 Receiver
Hi I have an Onkyo TX-SR875. The AV receiver display panel has gone, so I reset it to factory defaults to see if it would bring it back - it didn't. Worse can't now see the on-screen setup menu to setup...
This is a common problem on onkyo receivers like the 805, 875 etc. The front panel display board has 2 faulty resistors(marked 9304 & 9310) which can blow out easily. Replacing them with some very basic soldering, resolved the issue for me.
View this link on the AVS forum for detailed instructions .
Look for the post titled "805 Display fix"
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=578
Dec 06, 2008 | Onkyo TX-SR875 Receiver
On-screen Menu not appearing on Onkyo-TXSR875
onkyo UK referred me to their UK repairer called GenServe and they were vary helpful, said it was a common fault!  I just happened to live near GenServe and I took it to them and they fixed it in a couple of hours and as it was still under the 2 year warranty, it was fixed for free.  Not sure where you are in the world, but check out their website www.genserve.co.uk
875 onkyo
Front Display Panel.
Sorry for the confusion
Oct 09, 2008 | Onkyo TX-SR875 Receiver
No display on my sr875 the next time i turned it on..i have no clue waht happend..it was just working fine yesterday,now, it suddenly shows one issue that needs to be resolve..i did everything i cud do but...
The 10 Ohms resistor R9304 in series with the the 44V display power supply was open.
How to find it:
Remove the to cover.
On the right hand side of the front panel you will see on the side a wide white flat cable going toward the back of the receiver.
Beside it is a 4 black wire band connecting the front panel to a 3x4cm power PCB which is parallel with the front panel inside the receiver (attached to the front frame).
It has visible on the left side a diode bridge and a fuse - above the fuse you can find the R9304, a SFR16 package (1x3.5mm) marked BrownBlackBlack.
Check continuity.Replace if open wit a 1W resistor
Good job ONKYO, save 1/3 of a penny...
For the DIY:
As an added step I replaced the R9304 with a 2W 47R resistor, replaced the series transistor regulator Q9301 (tall TO92) with a bigger package (isolated TO220) and one of the two series 22V zenners from the base - D9310 - with a 10V one.
Output voltage drops from 44V to 34V, display is slightly dimmer but overall stress is down.
Dec 14, 2007 | Onkyo TX-SR875 Receiver
Open Questions:
See all Onkyo TX-SR875 Receiver Questions
Onkyo TX-SR875 Receiver Logo
876 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
