Question about Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
Water squirts from tank while filling - Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 18 Answers
Take lid off and check that the fill tube is in place. If so flush with lid off to see were the water is squirting from, be prepared to clean up water...If you can, do a slight flush. If there is water coming from any where but the bottom of fill valve and the fill tube you may need to replace the fill valve. In my experience, the fill tube is dissconected.
For Diagram
http://www.askmehelpdesk.com/attachments/plumbing/19906d1242687133-shut-off-valve-under-toilet-doesnt-work-fluidmaster-20ballcock.gif
Posted on Jul 07, 2010
  • Clayton Jr
    Clayton Jr Jul 17, 2010
    Curios if this was helpful?
Not enough water in the bowl
Take cover off tank and check to see if the small tube that squirts water into the overflow tube is actually discharging into the overflow.
If this is unclear flush toilet with tank lid off and observe operation.
Generally there is a small metal clip that holds the small tube to squirt into the overflow.
May 11, 2016 | Toto Cst416m-01 Aquia II 2-Piece Toilet...
Why won't it start after running out of gas?
Hi Joe:
Don't know what "it" is, but the fuel pump needs to cycle enough to prime, the carb or injectors need to be filled with fuel.
If it is a carb, remove the air filter and look into the carb...... pump the throttle linkage...... the accelerator pump should squirt gas into the throat of the venturi. If there is no gas, a squirt of gas to prime won't hurt.
Dec 06, 2015 | Cars & Trucks
Just filled my tank this morning. went to start the car before work and it turns over wants to start but sounds like it is starved for gas?
Possuible water in gas. try a squirt of gas into the carb, if it starts you might try a fuel additive to get rid of water in the gas.
Sep 30, 2013 | Worldwide 1994 Saab 900 SE 2.5L Alternator...
Maytag msd2758ges ice maker squirts water
Sounds like the water solenoid is not shutting off cause once the tray fills it should stop sending water located in the back bottom with the water lines connected
Mar 24, 2013 | Maytag MSD2756GES Side by Side...
Pump running but water won't go through
I had the same problem for the longest time until today. I took a super soaker squirt gun (hand style with single pump on top) and shot it up the hole wear the water intake is for the pump (on the bottom of the white plastic part that has the trigger and water pump inside) while holding the trigger down to have the pump running, too. Did it a couple times for good measure. ;) When I tried it with the tank attached, it worked again. After that, I ran some rubbing alcohol through it to clean it up a bit but you could probably use hydrogen peroxide or distilled white vinegar as well. I'm guessing that the salt and baking soda mix eventually builds up and plugs it. Definitely plan on keeping the squirt gun handy in case it happens again. Hope this helps.
Dec 19, 2011 | Water Pik Waterpik SWI 615 Sinusense Water...
WHAT HAPPEN WHENT I PUT WATER IN MY TRUCK TANK AND THE WATER GO OUT FOR THE PASSENGER MUFFLER SIDE 97 FORD F 150
It sounds like you have a blown head gasket or cracked cylinder head. These are usually caused from the engine over heating. if the leak is that server a quick check would be to fill the radiator with water and leave the cap off, then crank the engine over if the water comes squirting out from the radiator its a good to say its in the head gasket or cylinder head. Good luck
Aug 28, 2010 | Ford F-150 Cars & Trucks
Cant squirt water, nothing is coming up from the carpet
Try filling soap solution tank with hot water and make sure that the red filter in the pickup tank is not clogged, and always run hot water in solution tank after cleaning carpet. steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Windsheild Wiper Fluid will not squirt on windshield
While you were filling the tank you may have disconnected the pump wires. If you can hear the pump activating when you use the switch then the pump may have gotten clogged , check for sediment in the tank.  For the person with the mustang - if its only coming out of one side then its a nozzle clogged or a pinched hose.
Dec 11, 2008 | 1994 Jeep Grand Cherokee
Bissell 1699 not dispensing water
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Jul 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Carper cleaner not working
Is the duct(#11) that sits in front of the dirty water tank in place? Is the lid of the dirty water tank on tight all around. If there is a foam filter on the inside of the dirty water tank, is there a gap between the top and the filter? Also there is no heater in the unit, so the only hot water is what you fill the tank with.
Jul 29, 2007 | Hoover F5832-910 SteamVac Supreme Vacuum
Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand Logo
451 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
