My air conditioner won't turn on. I have flipped the breaker, I have changed the thermostat batteries, have checked the filter and it is clean, have tested the furnace but still can't find the problem
  • 1 more comment
  • pepsi_chic18 Jul 06, 2010
    I tried turning the fan from auto to on and it did not run. Out of curiosity I turned the heat on and got it to kick in and the fan works with the heat. I don't know what a jumper is and might have to break down and call a professional.
    The fan kicked in! All on it's own. I wonder if the record breaking heat has anything to do with it. Praying the A/C unit does the same...
    I'm not sure what the insulated suction line is... but I don't hear anything running.
  • 456 Answers
Turn your fan from auto to on, your fan should run. If it does not turn on you have a 24volt problem.
Go down to furnace and remove thermostat wires at control board. Install a jumper between R and G. Put door back on and turn furnace on. If fan comes on you have a wiring or control issue, If fan does not come on iot is possible that a little 3amp fuse located on the board is blown or your tansformer is bad.
Remove jumper bewteen R and G and put it between R and Y. Put door backon and turn on power. If your AC starts, you have a wiring problem.
If it does not start, did you check to make sure the breaker or fuse is not blown on the air conditioner?
Posted on Jul 06, 2010
  • Frank Bryant Wetzel Jul 06, 2010
    It could be that your thermostat is not wired to have fan on operation. Turn it to cool and the fan should come on as well. It
    does not matter what the outdoor unit is doing.
    If the fan comes on in cool mode then at least you know you dont have a control issue and the problem is outside
    Go outside as you should be able to hear the compreesor run. Also the insulated suction line should be cold.
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
How to get Goodman air conditioner to pump cold air in after changed filter?
First, remove the air filter and check the coils above or immediately adjacent to the location of the filter. They may be clogged. Use a soft brush to remove lint, hair and grime. BE CAREFUL TO NOT BEND THE DELICATE FINS ON THE COILS. If they are clean then if your AC is a forced air system (whole house) do the following.
Is the compressor running? That is the big box unit outside of the house. You may have to turn it off at its breaker (separate from the air handler where the filter is located and usually outside the house near where the meter is located.) Leave the breaker in the off position for 20-30 minutes before turning it on again. Set your thermostat to 66 degrees or there abouts before turning the breaker back on. After turning the breaker back on, if the compressor does not start up within a few minutes, then it is possible that one of the startup capacitors is defective. If you do not feel comfortable working around 230 volt electrical systems, call an AC repair shop and have them do a system check.
Aug 11, 2012 | Heating & Cooling
Dometic rooftop a/c compressor will not shut off. The only way to stop the compressor is to shut it off at the breaker. The fan and all other funtions operate properly from the thermostat. I tried...
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Oct 03, 2011 | Dometic 57915531 Air Conditioner
I have a Trane xr12 air conditioner. I turned off 230v breakers at the air handler, cleaned the filter and turned the breakers back on. now the compressor doesnt come on. I checked the relay on the...
Is the blower coming on inside? If it isn't, try tripping both breakers again. If the blower is working, your thermostat may be timed out or the air cond may have a timer in it that will keep it from coming on for a few minutes.
If none of the above work, make sure you didn't pull any wires off when you pulled the filters out.
May 28, 2011 | Heating & Cooling
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
How do you re-set error code for "change filter" when filter has been changed on Carrier programmlbe thermostat
Clean Filter Feature -
The thermostat will display the CLEAN FILTER indicator when it is time to change the filter. Press the Reset Filter button to restart the timer after the filter has been changed or cleaned. Helpful?
Dec 28, 2010 | Carrier TSTATHCP Programmable Thermostat...
Air conditioner keeps flipping the breaker
Could be a lot of things. About the only thing you can do besides calling a service tech is to 'make sure your coil on the condenser (outside) is clean. This coil can be cleaned with a water hose, but you need to make sure you have all electricity turned off.
Turn off the breaker on the outside unit (this could be a fuse block that you have to pull out) and make sure you have your inside thermostat in the off position.
Once you are 'absolutely sure' that you have all electricity off - you can wash the coil with a high pressure hose. Just make sure that both - the inside and outside of the coil is clean; you may have to disassemble the unit a little bit, i.e. take the top off or one of the sides, etc.
The only hope you have - is that the coil is clogged and causing the compressor to overheat and go off on amp overload. It's possible this is the case - but I also suspect the compressor is electrically breaking down which is not connected to the condenser coil being dirty, in which case you will need a service tech and may be faced with some expensive repair. Let's hope this is not the case.
So - it's worth a shot to wash the outside coil.
Not to be 100% negative - it's possible it's something minor and when a service tech looks at it - it could be a fairly cheap repair bill.
Good Luck!
May 02, 2010 | Ruud UBHC Air Conditioner
I had a 14 seers Trane installed 18 months ago. The thermostat goes blank and the system doesnt come back on until I flip the breaker or disconnect power to the ac.
try replacing the batteries in the thermostat on your wall. probably has 2 AA's this may fix it if not may have bad or old wiring from tstat to main indoor system. when you had a trane installed did they change the air condition components only(likely) or did they put in new furnace, new wiring, new t-stat, a full install?
Sep 11, 2009 | Ruud Central System Air Conditioner
MY AIR CONDITIONER TRIPPED ,NOW IT WONT COME BACK
Unplug unit let set till cool then turn on motor has heat trip button that will pop out so it wont over heat, It should pop back in when it cools off. Make sure filter is clean and condenser is not iced over by high humidity. If unit still wont come on check house fuse or breaker it should be on a circuit by it's shelf, flip it off and back on so it is closed all the way.
Jun 27, 2009 | Fedders A6P09S2A Air Conditioner
Air Condition will not come on. We have tried to flip the breaker but no success. The fan on the air condition inside and on the outside is not turning.
If you have one of those new digital thermostats try changing the battery. If your air conditioning is run through a central heating system the power must be on to the furnace. 24 volt control circuit gets its power from the furnace in this kind of case.
Jun 30, 2008 | Heating & Cooling
Heating & Cooling Logo
346 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
