Question about Miele W1926A Front Load Washer
The washing machine door will not open. We changed the fuse but it still does not work.any other suggestions.
    Genius:
  • 1,075 Answers
This can be a problem its not easy,the top needs to come of the machine and the latch screws undone.The problem is the switch on the door, its a common problem on front loaders you need to call an engineer to do the job unless you are brave and try it yourself?????if you do i will take you through every step but remember its not easy.adrian,,,,,,
Posted on Jul 06, 2010
I have a Samsung DC68-02683A washing machine. It was working perfectly fine earlier and now will not turn on - there is no power. I unplugged it and left it off for upwards of an hour. It will not power on...
Hi
Check the power supply/fuse in the first place. If the supply is right then the problem is of the door. Try to push the door a bit hard and try to open the door. When the machine is switched off the door has to open, find out if it is not stuck. Finally if things dont go your way call a mechanic.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 27, 2011 | Samsung Washing Machines
Hi, I have a Hotpoint Aquarius 7kg WDL520 washing machine. I have just went to open the door to hang out a wash I did earlier. The door is locked and no power seems to be in the washing machine as...
Does it have a separate drawer for the detergent and softener? sometimes opening that will unlock the door. It sounds like it was overloaded and blew an interior circut
Oct 21, 2010 | Washing Machines
Machine partially fills and then stops working.
THE RCD SWITCH is concealed on the inner side of the hindges of the door or on the top innerside of the door. it is a simple push switch which has a mechanism of push to on/off
this switch has got stuck in off position.
change this switch or spray a drop of rust removal oil. it will start functioning
Aug 27, 2009 | Whirlpool AWM8123 Front Load Washer
MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing machine wont turn on
sounds llike the door interlock mechanism which will stop the poer coming on look up washing machine lock on ebay
steve
Sep 28, 2008 | Hotpoint Aquarius WD63 Front Load...
Washer door won't open (hotpoint first editon 800)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
Aug 13, 2008 | Hotpoint First Edition FEW12 Front Load...
Door open? is displayed
Exact same problem happened to me (door open? when start button pressed); was not the machine, it was the wrong volts. An electrician tested the wall plug (it was 110) and changed the fuse in the fuse box to 220 volts and has ben running smoothly.
May 28, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Creda 120vw washing machine fuse changed still no life
You start looking from the power plug, down to the power-cord. The power point in the wall, (plug in something else to check power), the pause switch on the machine, any lights on the machine? Did you open the door to get the clothes out?..........
Careful when the power is on & the top off.........
Dec 22, 2007 | Creda W100FW Front Load Washer
Hotpoint WD52 washing machine door not opening
hi when your fuse blew it welded contacts inside door lock mech replace and all will be fine **** it could have been the door lock that blew fuse but check carbons whilst you have top of ALL THIS IS DONE WITH THE PLUG OUT DONT FORGET
Sep 20, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Miele W1926A Front Load Washer Logo
180 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
