Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
WHY IS MY DRYER NOT DRYING ON NORMAL CYCLE?
IT DRYS ONLY ON BULKY
Whirlpool dry gew9200lw0 problems is contorl locked what the solution
Posted on Jul 06, 2010
My whirlpool duet dryer will not allow a normal cycle, it swicthes to delicate or bulky items
The control board is failing... I would use it until it will not dry clothes at all, then get it rebuilt for a fraction of what a new control costs. CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
This place rebuilds controls and offers a one year warranty for about 130 bucks
May 22, 2016 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Takes 4 to 5 dryer cycles to dry one load
usually thats a blocked vent to the outside..Its wet on the inside because its holding the condensation from the clothes .also check blower wheel ..One sure way is take your vent off the back of the dryer and dry a load if it drys in a normal time you know your out going vent is plugged
Feb 18, 2015 | GE Dryers
How long does it take in a full cycle of wash to dry
Depends on several things. How big the drum is eg 6 kg or 7kg .the spin speed... The material ie. cotton drys faster than woollen items.is it a washer dryer or do you have a separate dryer.normal full load 6kg on a 1200 rpm spin of mixed fibres takes 1 hours 30 mins at 40 c then the dry time can take roughly 1 hour to 90 mins.
Dec 23, 2014 | Washing Machines
Too long to dry
When you say too long I assume the dryer does heat simple trick disconnect exhaust tube from dryer at bottom run a cycle room will get hot if dryer drys correctly then you have a restriction in the exhaust, dryer has to be able to breath just like a muffler on a car a restriction will cause the heat circuit of the dryer to cycle on/off on the hi limit instead of the cycling thermistor which will give you a long dry time hope this helps
Mar 22, 2014 | Whirlpool GEW9200L Electric Dryer
My Maytag Bravo dryer adds extra minutes to cycles. If I set it for normal or bulky it will run for some time and when I check to see if it's done it still has over an hour left on it, more than the...
Your dryer has a moisture sensor, if it senses that the clothes aren't dry enough it will extend the cycle. A couple easy things to check:
1. Be sure the spin cycle on your washing machine is working properly. If the clothes are too wet when you add them to the dryer your dryer will need to add more time to get the clothes dry
2. Be sure your lint filter is cleaned after each load, and have your dryer exhaust vent cleaned- it could be clogged.
Oct 29, 2013 | Maytag Dryers
1995 Kenmore Dryer heating issues
Sounds like a Heating element. Most towns have a do it you self appliance repair store. Contact them to price the part. Have you tryed vacuming th ling from the inside of the unit. Sometimes they get loaded with lint and does not heat efficiently. Hope this Helps.
Jun 21, 2013 | Dryers
My dryer is getting hot but clothes aren't drying what can be the problem? It runs for the full cycle too.
Check your venting to make sure there is no restriction. If you cannot find a restriction, unhook your venting from your dryer, pull it out two feet from the back wall, and run a normal load through the dryer. If it drys fine, you have a venting restriction, and it is not the dryer. If it still does not dry with the venting removed, you have a thermostat or thermistor problem. Good Luck, Appliance Specialists
Feb 16, 2010 | Dryers
Gas dryer wont trun off after drying
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 08, 2009 | Dryers
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
169 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
