Question about Jenn-Air JGS8750 Gas Kitchen Range
Our 4-year old Jenn Air gas stove (PRG3610NP Model) does not work. I thought it was the ignitor and changed that out. Both the stove and the broiler ignitors work fine. No gas seems to be getting to the stove even though the gas turn-on is in the on position. All the burners work fine. Thanks, Mark
  • 22 Answers
SOURCE: Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Posted on Dec 03, 2007
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
Cory5468
  • 125 Answers
SOURCE: spark ignitor won't stop clicking
Dry the ignitors and see if that works. If not, then get new ignitors.
Posted on Apr 14, 2008
  • 1314 Answers
SOURCE: GAS STOVE
yep replace the bottom ignightor take out the rackes remove the two bott screws in the oven remove the bottom plate and just keep going down
Posted on May 21, 2008
SOURCE: jenn air range, model CVG4280B,
I do not know the cause BUT the fan behavior (on for left burners, off for right burners) is by design. The high-speed fan has two switches; 1) the primary switch visible centered between top two knobs, 2) secondary switches integrated with left burner knobs.
Posted on Jul 13, 2008
Broiler does not light....Put in new ignitor; still not working. Checked orfice to make sure its LP and not Natural gas. Its number is #56...Is this correct for LP?
The Jenn-Air Broiler LP broiler orifice is part number: AP4091112. A picture of the part is here: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-orifice--broiler--lp--item-number-ap4091112.aspx . (To me the number looks like 65 to me. The natural gas version is number 47.)
Check the current draw at the igniter. (The meter must be in series with the igniter. I know the bake igniter needs to be above 3.2A.) Other possible causes of the problem are a selector switch problem or the glow bar. (These are things to check if the oven works.)
I hope this helps.
Jul 30, 2011 | Jenn-Air PRG3601P Gas Kitchen Range
Gas oven doesn't work. Broiler does.
Hello - Most likely failed lower burner ignitor. Tests good if above 4ohms. Part is 40$. Can give replacement instructions if needed. Let me know if this helps. Thanks. -ED
Mar 03, 2010 | Jenn-Air JGR8875QDS Gas Kitchen Range
My jenn-air gas oven works when i put the broiler on but the oven will not come on
i would replace your bake ignitor, as an oven cycles the broil ignitor and bake ignitor on/off to preheat the oven.. if ur bake is not coming on i would replace it, hope this helps
Feb 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
Gas top burner not lighting ( 4 others work )
It's probably the ignitor and there may be soemthing clogging one of the gas holes. You can gently use a scrub brush to dislodge any cloggs and see if that helps. You might have to replace the ingitor if this doesn't work. We have parts, so please call us to help. Hope this does the trick for you. Ella
Aug 19, 2009 | Jenn-Air JGW8130DD Gas Single Oven
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
PRG3610NP
when you buy a new stove the manufacture installs a small cap on the stove side i know its silly you probably removed that part before you installed the flex line just check that if you did already well then i,m stump-ted thanks the appliance doc
Sep 22, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
Jun 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn-Air JGS8750 Gas Kitchen Range Logo
90 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
