Question about JVC KD-S550 CD Player
1994 toyota pickup - trying to install a jvc car stereo - all wires match up, clock will come on for a moment and then turn off. no sound either.
  • JVC Master
  • 17,130 Answers
First of all have you tried to check the set before installing. If not test this once again. please take care to see if the main power , the standby power and the ground is given right and into the right path. make sure that the ground is taken correct. once this is right , your set must work. switch off and then you can connect the speakers. Hope this helps. good day
Posted on Jul 06, 2010
Need wire diagram for 1994 toyota windom
Whether your an expert Toyota Camry mobile electronics installer, Toyota Camry fanatic, or a novice Toyota Camry enthusiast with a 1994 Toyota Camry, a car stereo wiring diagram can save yourself a lot of time. Automotive wiring in a 1994 Toyota Camry vehicles are becoming increasing more difficult to identify due to the installation of more advanced factory oem electronics.
One of the most time consuming tasks with installing an after market car stereo, car radio, satellite radio, xm radio, car speakers, tweeters, car subwoofer, crossovers, audio equalizer, car amplifier, mobile amp, car amplifier, mp3 player, ipod or any car audio electronics is identifying the correct color car audio wires for your 1994 Toyota Camry.
The Modified Life staff has taken all its Toyota Camry car radio wiring diagrams, Toyota Camry car audio wiring diagrams, Toyota Camry car stereo wiring diagrams, Toyota Camry car radio wiring schematics, Toyota Camry car wiring diagrams and cataloged them online for use by our visitors for free. Our automotive wiring diagrams allow you to enjoy your new mobile electronics rather than spend countless hours trying to figure out which wires goes to which 1994 Toyota Camry part or component.
Jul 26, 2012 | Compaq Presario AMD V120, 2GB, 160GB HD,...
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
How do u hook up a jvc car stereo in a ford taurus
To make this installation you are going to need a wiring schematic for that vehicle, your local Ford dealer should supply that for you if talk nicely to them and they have not purged that book from their inventory
Jul 28, 2010 | 1994 Ford Taurus
Does a 1994 Stock Toyota pick-up 2wd. Come with stereo wiring?
there is no wiring for a stereo system at all (toyota,along with all major makers, skimp on everything,allowing you to fit a system that,if you can afford it,will "fill the grand canyon with sound"
Apr 17, 2010 | 1994 Toyota Pickup
Trying to hook up a new stereo. Where can i find a wiring schematic for a 1994 toyota pickup?
Car Radio Constant 12V+ Wire: Blue/Yellow
Car Radio Ignition Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Stereo Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope this helps
Dec 10, 2009 | 1994 Toyota Pickup
Im installing a new stereo and need a wireing digram
You'll need to determine which of these connectors match yours, then follow the appropriate diagrams:
Nissan Audio Wiring - 1985 to 1994:
Nissan Audio Wiring - 1995 onwards:
Let me know how you get on...
Cheers,
Scott
Nov 12, 2009 | 1994 Nissan Pathfinder
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
Help with installing a JVC kd-s15 in 91 accord
It sounds like you blew a fuse. Check in the fuse pannel under your dash. Check mainly the one that ties all three together. If that is blown, replace it and if it blows again I would double check all connections and verify them with the diagram to make sure the proper wires are connected. I know that on some wiring harnesses the colors are different. I ran in to that when I installed my stereo in my second car.
Mar 16, 2009 | JVC AM FM CD DET FACE CAR STEREO
Clock and the radio
they have 2 fuse boxxes 1 under dash and 1 in engine compartment
Feb 20, 2009 | 1994 Toyota Pickup
1986 Toyota pickup stereo wiring COLOR CODES NEEDED
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Illumination Wire: Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Sep 01, 2008 | 1986 Toyota Pickup 4WD
JVC KD-S550 CD Player Logo
253 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
