Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Bad smell in Bosch nexxt WFMC3200 washer
I really don't think this washer is so bad as some make it out to be.
It appears to be fairly stout in design.
The gray seal connecting the outer tank to the case of the machine is sort of vulnerable but looks easy to change.
I think I may have stumbled upon a solution to the odor problem in this machine, however.
The outer tank has a short hose going to the drain pump. There is no filter there. The output of the pump goes to a sort of J tube much like an ordinary sink drain. This was filthy in my case. Keep in mind that this machine had odor problems for about three years. It just developed this problem.
The J pipe has a hose from itself to the pump. This was full of nasty smelling stuff. In addition, I discovered that there is a check valve and a small hose going to the top of the drum. I assume this is an overfill protection where water can drain from the drum to the drain if the supply level sensor fails.
I believe that this check valve was stuck and was allowing dirty water to be admitted back into the drum. With this dirty water sitting in the drum, it is not too surprising that the thing began to smell.
Anyone else with this experience? Any hints to help keep it from recurring?
  • Gary Follett Jul 06, 2010
    I meant to say that this machine had NO odor problems for three years. Thus, I know it is capable of operating without smell even without continuous maintenance and without cleaning the drum after every use.
    I was very happy with this machine in every way until this smell issue arose about 6 months ago.
  • 31 Answers
Check where water might be building up at door if front loader. Mildew will start. On some units free kits were given to repair standing water issues. You can run a small load with bleach (without clothes) to wash away any mildew, however, if there is a drain issue, bleach can also be held back and later affect clothes. If you have mildew in hoses, I would question how water is not being pumped out, is the drain hose higher then the unit itself?
Posted on Jul 07, 2010
Testimonial: "Thanks for the pointer. The drain is a sink feed and its outlet is below the washer top where the pump pushes the water. I really think that the check valve was stuck open and allowed the dirty water to flow back into the drum."
  • Bosch Expert
  • 414 Answers
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Posted on Jul 06, 2010
Testimonial: "Thank you for this very helpful information. I was sort of thinking there must be some effective means to clean the inner portions of this machine but was unsure what to use. "
Nexxt Washer Problem
timer not sending signal, or bad transmission
May 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch nexxt series 500. error eo4
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Nov 29, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Mold inside the rubber seal as well as inside the glass in the door. Clothes are not fresh. I have to keep the door open due to the smell.
Bosch Nexxt Premium WFMC6400UC Front Load Washer mould on rubber seal.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 18, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
My washer smells really bad
your smell is comming from over soaping
a front load machine only needs 1 Tblsp of soap
any thing it builds up and rots thus the smell
get a crystal dish soap
1 cup run the machine empty a full cycle
now use trhe proper soap it will clean away
Oct 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch washer smell
Just clean the filter and make sure all the water drains from the pipes, That water can be a realy smelly story, i know.
Good luck...
Sep 07, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
And don't forget to like us on facebook
Mar 15, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Essence Washer
start a cycle, once the door lock light comes on pull on the door to see if its really locked if not, you need a new door lock assembly
Nov 12, 2007 | Bosch WFMC2100UC Nexxt Essence Washer
Bad Smell
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Aug 31, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
563 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
