Question about Pride Mobility Products Health & Beauty
Draw on Pride scooter batteries
I have a Pride Celebrity scooter and there is a draw on the battery when the key is off and I can isolate the circuit by pulling the fuse. I need to know what the fuse that I pull controls. Can anyone help. I can not find a schematics. The batteries are new.
  • canchaser5 Jul 06, 2010
    I put new batterys on my Pride Celebrity scooter. With the key off there is a draw on the battery. This system has three fuses on it.
    One is a 3 amp fuse. I can pull the 3 amp fuse and there is no draw on the battery. My question is, I need to know what this 3 amp fuse protects. I can fix the problem if I know
    where to look. thanks.
  • canchaser5 Jul 07, 2010
    This helped to know what the 3 amp fuse controlled.
    Thanks,
  • 2,272 Answers
Your scooter requires two long-lasting, 12-volt, deep-cycle batteries that are sealed and maintenance free. They are recharged by an off-board charging system. ! Charge your scooter’s batteries prior to using it for the first time. ! Keep the batteries fully charged to keep your scooter running smoothly. READING YOUR BATTERY VOLTAGE The battery condition meter on the tiller console indicates the approximate strength of your batteries using a colour code. From right to left, green indicates fully charged batteries, yellow a draining charge and red indicates that an immediate recharge is necessary. To ensure the highest accuracy, the battery condition meter should be checked while operating your scooter at full speed on a dry, level surface. The off-board charger supplied with your scooter is equipped with a 115/230 voltage switch. Confirm that this switch is in the proper position for your locality. If you are not sure what the voltage is in your country, contact your local electricity dealer before inserting the charger power lead plug into your wall socket. If the setting is incorrect, the charger will not function properly. Slide the voltage switch to the appropriate position. The fuse controls the internal wiring harness.When its remove the wires controlling the scooter stops functioning.And due to that battery stops drawing. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 06, 2010
  • raj somaiya
    raj somaiya Jul 07, 2010
    Tiller Console Fuses are for light control turn signal and key switch console system.
    The 3 amp fuse is for manual freewheel lever.
    3amp off-board charger fuse for battery charger.
    Thanks for the query.
  • 472 Answers
If this manual can be any of your help.
To download click on the link below
http://tinyurl.com/2wapgv8 http://tinyurl.com/35rvoq8
Good Luck!
What size batteries go into a celebrity x mobility scooter with four wheels
Pride Celebrity SC400 SC4001 Battery Replacement Kit
There is technical support offered at the Pride Go Go website. The site above simply offers a replacement. Further specifications may be obtained from them or a manual.
Pride Mobility CELEBRITY Owner Manual
Aug 12, 2017 | Health & Beauty
Can anyone help me? I own a pride celebrity lx8 scooter. It is beeping 3 and 1 or 3 and 2. What could this mean please? Many thanks R
Yes I done a quick search on the beeps it took me to the same fault codes as the book TRY SENDING AN EMAIL TO www.pridemobility.com.au....good luck..Hi again yes I just picked up the fault book and they call them flash codes I WILL CHECK INTO THE PROBLEM cheers. Hi 3 flash code unplug charger turn key of then back on again , 1 flash code charge batteries 2 code same as 1 charge batteries good luck
Jul 06, 2016 | Pride Health & Beauty
Error code 5 pride celebrity x
The manual freewheel lever is in the (forward) freewheel position.
Remove the key from the key switch, then push the manual freewheel lever to the drive (rearward) position and restart your scooter. The manual is at...
http://r.duckduckgo.com/l/?kh=-1&uddg=http%3A%2F%2Fwww.pridemobility.com%2Fpdf%2Fowners_manuals%2FUS_Scooter%2FUS_Celebrity_X_om.pdf
May 27, 2014 | Amigo RD 3-Wheel Scooter w/33AH Batteries...
Why wont my celebrity x3 charge
Try the Charging circuit fuses hidden under the mat and floor hatch.
Is the charger OK?
Are the batteries coming to the end of their life?
Apr 25, 2014 | Pride Celebrity X 3-Wheel Electric Scooter...
Why wont my celebrity x take a charge brand new batteries brand new charger
Is the charging circuit fuse blown? There are two hidden under the floor mat and hatch. Pride say that they don't exist, but there they are and one of mine mine was blown by a faulty XLR lead
Apr 25, 2014 | Pride Celebrity Xl 4 Wheel Scooter
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Nov 04, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
Lost key to Pride Celebrity Scooter. Have an extra key for another Celebrity scooter. Are keys interchangeable? Thanks, DJ
DJ should work try it if all else fails call Pride @ 1-800-800-8586 ask for tech Support and ask to get a set of keys or You can replace the keyed switch with a on/off toggle switch Hope this helps
May 05, 2011 | Pride Mobility Products Pride Mobility...
I turn key on celebrity scooter. everything looks normal. all lights on, but does not run.
Are the lights flashing or steady? If they are steady and indicate that the battery is charged, make sure that the freewheel/manual brake release lever is in the drive position. If the lights are blinking, then you can visit this site to locate the type of controller on your scooter to try and determine what the problem may be: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
If you continue to have problems, please contact Pride Mobility Technical Support for assistance.
Dec 22, 2010 | Pride Mobility Products Pride Mobility...
Celebrity Pride SC440 scooter makes continuous clicking sound
the motor break assembly is going bad, if not replaced soon it will quickly draw down your batteries. smithrm70@hotmail.com
Sep 11, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Health & Beauty Logo
85 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
