Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Top draw beeping delay and water not draining
Fisher and Paykel 2 draw dishwasher :
Top draw beeping "delay" and water not draining.
How do I remove top draw to clear pipes??
  • Fisher and P... Master
  • 3,247 Answers
Not sure what you mean by beeping "delay" I am not sure if there is any such light on the dishwasher. The HRS DELAY is displayed on the LCD when dishwasher has been set in delayed start mode. Are you seeing this flashing in an orange background? There could be several reasons for water not draining. Does the beeping go away if you press the power on/off button? Also does the delay flashing stop. Have you checked to see nothing is blocking the drain pump which is the same rotor that drives the washer arms.. What about the kitchen down pipe - is it clear? If you think you have to take the drawers out to reach the drain hose then follow instructions on page 7 step 2 of the installation manual. It is for a later model but your one should be similar. Make sure you turn the mains power off when working inside the dishwasher.
Posted on Jul 08, 2010
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher paykel dishdrawer
The controller is detecting some abnormal condition. Clean the interior of the dishwasher with warm water and clean cloth. Remove the base drain plate etc., before cleaning and clean the plate separately. Put back and try again. If no difference, then buy Finish dishwasher cleaning kit and run the dishwasher on one of the hot cycles. (You will have to keep pushing the pause button ). See if it clears everything. If not then call the technician as the controller may need replacement.
Nov 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My Fisher Paykel DD603I top draw whines when it is first turned
The lid seal on the top drawer is faulty and needs replacement. It might be cut or damaged and is obstructing the drawer from closing. THis also may have caused the flood switch to trip as water can leak if drawer is not sealed.
Nov 29, 2012 | Fisher and Paykel Dishwashers
Fisher and paykel dishwasher top draw does not unload water after the wash
The pump is faulty or the drain hose is blocked. You need to take the pump rotor out from the base of the drawer and inspect the sump for blockages. Usually a seed or chicken bone stuck between the drain sump and the pump rotor sump.
Nov 26, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
After 2 minutes top washer blinks. Water does not drain
When I opened the top drawer the water seems to be accumulating in the drawer and no water is draining. The drain tube appears normal and not kinked in any way.
Jan 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Dec 31, 2008 | Fisher DS603W / DS603B / DS603I Dishwasher
DD601ver2
check for restriction in sump. ie remove rotor, push pipe cleaner or similar from filter sump into rotor sump
Jun 21, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
576 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
