Question about Samsung ML-2510 Laser Printer
My computer had a virus and i had everything fixed now my printer is not working it's not my toner because it's brand new and i reset it and still not working i lost my cd that comes along with the printer when you buy it please help
  • 222 Answers
How do I reset the toner low on brother 8065dn
At one side of the brother toner cart there is a WHITE PLASTIC POINTER. open the screw that fitted the white ring then slowly take out the white ring and push the POINTER to the OTHER END of the white ring. this should reset the page count. then fix the white ring to original position.remember to switch of the printer when you put back the toner to the printer. good luck to you and GOD bless you.
Jan 06, 2015 | Brother Office Equipment & Supplies
Brother printer MFC 7440 N says to replace toner and I already did
Did you insert a brand new toner cartridge or refill only, if you insert a brand new they read your toner cartridge, if you insert a refill toner cartridge, first you need to reset the toner cartridge, i think in the right side, or left please switch and back to normal position.
Aug 16, 2014 | Brother MFC-7440N Laser Printer
I am trying to reset my toner. i am getting a toner replace message after i have replaced the cartridge with a brand new one from brother.i've tried opening the cover, hitting clear and then *00 and...
You dont say what model it is but in 90% of cases with the brother printer, it is the fault of the toner cartridge. I am presuming that the toner cartridge you put in was a generic brand. On the left hand side of the toner cartridge there is a counter reset lever that needs to be in the correct position to reset the printer. You can either return the toner cartridge and request another or try to reposition the lever & gearing by taking off the left cover.
May 11, 2011 | Office Equipment & Supplies
Brother HL5140 won't print
Sadly this happens all the time - we have about 12 of these printers and 2 have the same problem at this moment and the only fix we have found previously is to replace the drum unit with a brand new one which is hardly economical - indeed the machines are all NHS funded and often the solution has been to throw the printers with this problem away and we have a few defunct ones piled in a corner because of this - if anyone knows why and how this happens ( the tech dept locally has no ideas but just wupply an new printer as they are cheap) I would be very interested also - changing the drum and cartride to a partly used one from a different machine does nothing at all either so it has to be something to do with the chip in the new drum resetting the machine but how and why is beyond us. In every case the printer prints perfectly before the fault and after the change to a new drum so I can only assume it is a way of generating more drum sales??
May 28, 2009 | Brother HL 5140 Laser Printer
Toner light on, will not print
These printers rely on a manual lever on the side of the cartridge to tell the printer there is a new toner cart. The lever has two arms for the 550 (low yield) and one lever for the high yield cart. It sounds like the gears were not reset on the cart. Is the cartridge brand new, or remanufactured? I can give you more info on how to reset the cartridge.....
Mar 10, 2009 | Brother HL-5250dnt Laser Printer
Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Apr 26, 2008 | Dell 5110cn Laser Printer
Dell 1710n printer problem...
Try resetting the error lights with a drum reset. With the power on and cartridge door open, press and hold the Cancel button until all lights flash in sequence. Release the button and close the door.
Feb 28, 2008 | Dell 1710n Laser Printer
HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
HELP! Brother MFC-8460 "Toner Life End" won't clear
The problem with a new toner cartridge that will not signal the printer that it has been changed has to do with a gear positioned wrong on the new or rebuilt cartridge... we had 3 factory brand new toners that would not clear the replace the toner message... I finally found the following link that came from a toner company that sells refills that tells how to reposition the gear to let the machine know a new cartridge has been installed. I did the proceedure on pages 5 & 6 having to reposition the gear and all cartidges then worked flawless... it works.
http://www.castleink.com/265/cartridge/TN580.pdf
Dec 20, 2007 | Brother MFC-8460N Laser Printer
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
Samsung ML-2510 Laser Printer Logo
32 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
