Question about Pioneer DEH2200UB with iPod Direct Control and USB Input Car CD MP3 Player
The Pioneer DEH-2200UB USB port troubles
The Pioneer DEH-2200UB USB port is giving me trouble, when i plug in my Archos, it only says "check USB". It was working just fine last night, and this morning it went crazy.
jbreth
  • 69 Answers
SOURCE: Pioneer DEH-P4000 DFS Alarm driving me crazy
How to disarm DFS alarm How to disarm DFS alarm Disarming alarm Upon entering your vehicle and within the ENTRY DELAY TIME set within the DFS alarm Menu, attach your Pioneer Detachable face. If you have forgotten the Detachable Face Panel: If the STARTER DISABLE is ON, insert the ignition key in the ignition within the ENTRY DELAY TIME, then turn the key from OFF to ON 5 times within 1 minute. If the starter disable is OFF, insert the ignition key in the ignition and turn the key from OFF to ON within the ENTRY DELAY TIME. CAUTION: If the starter motor will not run, the cause may be the DFS alarm. To check whether the DFS alarm is cause, try switching the position of the switch installed according to the AVOIDING TROUBLE section of the installation manual. If the DFS alarm is the cause of the trouble, then the starter motor will run. In case, confirm DFS alarm operation in safe place. If there is no problem, switch back to its original position. If left at the newly switched position, some functions of the DFS alarm will not operate. If the starter motor will not run after switching the switch, something other than the DFS alarm may be causing the problem. Have the vehicle checked at a nearby dealer. ----------------------------------------------- Select the DFS alarm feature ON/OFF mode (alarm ) in the initial setting menu. Press the arrow (up) button to switch the DFS alarm feature ON. Press the arrow (down) button to deactivate the DFS alarm feature. Press FUNCTION button for 2 seconds to enter the DFS alarm setting menu These are a couple of things I found to fix this problem. Here is the link that I got them from: http://www.pioneerelectronics.com/pna/v3/pg/support/knowledgebase/0,,2076_310069579,00.html Hope this helps:) Jason
Posted on Sep 04, 2007
Benimur
  • 6966 Answers
SOURCE: Connecting Pioneer DEH-2000MP to an amplifier
Hi and welcome to FixYa,
You would need a special adapter that connects to the speaker wires of the Pioneer DEH-2000MP and converts them to line level RCA ports. Something like the image below and available from here or most car stereo stores.
Good luck and thank you for using FixYa.
Posted on Feb 13, 2009
SOURCE: aux port
Turn off Radio with car on or key on. Press and hold the big volume button in for 3 seconds, and the radio will say initialise. Than press the FCN button till it says AUX. Than press the SEL button till it says "Aux ON ". Turn on radio and you should be good to go.
Posted on Apr 14, 2009
  • 4 Answers
SOURCE: Pioneer DEH-1100MP stereo no working
Is it older then a year? warranty or call18004211404. If your fuse is good check these. check you harness for a GOOD ground, check for power with a meter reader. For some reason on these units if your constant 12v and ignition 12v are both not hooked up it wont even do a thing. make sure both are connected. no loose connects?
Posted on Aug 16, 2009
SOURCE: how do you switch the illumination color from Red
Actually you can change the color. Turn the Unit off. Press and Hold MC. The menu will pop up, turn to Ilumi turn it to desired color. It only comes in Red or Green.
Posted on Jan 07, 2011
I installed my pioneer deh-2200ub and it won't turn on. I've disconnected it and re-wired everything again and have the same problem. I have a 2000 chevy s10 4x4. Does it have to be grounded for the power...
Turn the stereo off with the button in the top left corner. Hold the button down until the stereo is turned off.
Then push the function button on the remote control and you will see clock settings.
Dec 28, 2010 | Pioneer DEH2200UB with iPod Direct Control...
How do you install a pioneer deh-2200ub into a 1995 Chevrolet berretta?
You will need these parts from Metra Electronics :
99-3200 Dash kit.
In the instructions that come with this, it tells how to R&R the dash.
https://metradealer.com/files/products/INST99-3200.pdf
Either a 40-GM10 or 40-GM12 Antenna Adapter
and a 70-1858 Wire Harness. This wire harness plugs into your factory harness and then you can use **** connectors to match up the other side to the radio. Red to Red, Yellow to Yellow...etc on down the line. Radio mounts into dash kit and screws into dash.
Nov 26, 2010 | Pioneer DEH2200UB with iPod Direct Control...
How do you switch the illumination color from Red to Green on the pioneer deh-2200ub
Aug 15, 2010 | Pioneer DEH2200UB with iPod Direct Control...
I have a deh-2200ub model... everything is hooked up properly, but no audio. any ideas?
What kind of vehicle? If it's on a Ford, make sure you connect the blue/white power amp wire (Ford installs factory amps in their vehicles)
Aug 13, 2010 | Pioneer DEH2200UB with iPod Direct Control...
Having trouble settimg clock on cd car stereo
how to set clock for a pioneer deh-27mp
Mar 24, 2008 | Car Audio & Video
Pioneer DEH-P6900UB & Sandisk Sasa e280r
Did you format it while connected to a PC? If so check that you didn't format as NTFS, the Pioneer HU can only read FAT32 I think.
Sep 20, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer DEH2200UB with iPod Direct Control and USB Input Car CD MP3 Player Logo
253 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
