Question about Sharp VC-A560U VHS VCR
Setting tape counter to zero
How do I set tape counter to zero?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Use the remote and press clear.
Posted on Jul 14, 2010
  • betnj
    betnj Dec 19, 2012
    I have been trying to figure this out forever. Thank you so much for the anser. So simple...I should have figured out but didn't. Thanks again.
  • betnj
    betnj Dec 19, 2012
    Sorry mis-spelled answer.
Sharp vc-a412 will not reset to zero
You have to press the clear button on your remote control to put the counter to zero.
Oct 25, 2014 | Sharp VC-A410U VCR
The torque ranges increase at what amount on the dewalt DCD920 cordless drill
I wouldn't count on those setting to give you an accurate torque reading, the torgue setting are so that you don't counter sink screws to far or strip the heaes. Obviously the setting go from zero to fully closed. the increments usually go by units of 10 ft lbs, but are not all that accurate.
Mar 21, 2011 | Drills
When playing a tape it may stop randomly and the counter displays zero. I have to push play button again and it goes on; but may stop after a while. It does not depend on cassette type or tape length (I...
This would indicate a power supply problem in that the counter being reset. I would check the entire power supply for a any thermal broken solder joints and redo them with the power off. If you need further help I am in the Chicago area and am known as Skywave Tape Deck Repair.
Feb 07, 2011 | Teac V-8030 Dual Cassette Deck
Epson 1390 service is required.
download free software resetter epson stylus photo 1390
Jan 10, 2011 | Office Equipment & Supplies
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Tape Counter
Thank you.  The machine has a reset button that brings the counter back to zero. Still not sure it is working right but I'll see as I transcribe my tapes.
May 19, 2009 | Sony BM-840T Desktop Cassette Transcriber...
Video won't show up on comp monitor
check your inputs on that machine. there are settings that you need to do. when you put a tape in the minidv, does it play fine? if it does, you need to check your input setting on that machine..good luck
Apr 03, 2007 | Panasonic AG-DV2000 Mini DV VCR
Sharp VC-A560U VHS VCR Logo
132 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
