Mojo spinmaster 3 has a mind of its own!!! hi, 1 of my mojo spinmaster 3's has a mind of its own, when you turn the light on it initialises and everything ok, works for hours and hours once going buy when the music stops and the unit goes to shutter on the gobo's then waits 5 secconds and then turns off the lamp ok but when the lamp goes out the barrel starts turning arround and will not respond to anything, the others i have, there lamps just come back on and work fine when the music is played again. i will upload a video when i get time, reply needed soon! Thanks in advance.
  • Nathan
    Nathan Jul 06, 2010
    HERES THE VIDEO!:http://www.youtube.com/watch?v=uNdTt5E81... (Direct Youtube Link)
    And Hopefully The Embed Code Will Work:
    HERES THE VIDEO!: http://www.youtube.com/watch?v=uNdTt5E81QY (Direct Youtube Link) And Hopefully The Embed Code Will Work: <object width="640" height="505"><param name="movie" value="http://www.youtube.com/v/uNdTt5E81QY
  • Nathan
    Nathan Jul 06, 2010
    HERE IS THE VIDEO:
    stratcat50
    • 3 Answers
    SOURCE: Crown D-150 Amp
    Sounds like something was spilled into the amp and it got into the controls, switch and switch knob. As for the knob, lean the amp forward about 45 degrees and dribble hot water into the space behind the knob slowly. Try to keep the water from going inside the amp. Eventually, the knob should come off with some pulling & twisting. Once you get it off, replace both pots and the switch. If water gets into the amp just dry it up with paper towels, etc. and let it continue to dry while getting the new parts. HTH, Emory
    Posted on Oct 05, 2007
    Adolph
    • 137 Answers
    SOURCE: model LTV-27w2 westinghouse
    The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
    Posted on Dec 22, 2007
    • 1030 Answers
    SOURCE: TV suddenly shuts off and lamp light comes on, but lamp is OK
    did you reset the lamp timer? just a guess
    Posted on Feb 08, 2008
    • 96 Answers
    SOURCE: RE: Casio wk 3000 musical Keyboard only reads Ples Wait
    I am not shure but it sound like a hard drive problem, does it have a hard dribe that keep's it's memmory.
    Regards
    bob
    • 4 Answers
    SOURCE: NAD C370 in protection mode
    With closed eyes -replace all capacitors on protection PCB All of those caps are overheated and dry out (they lost there capacidance).Note that capacidance meter will not help you at all. Now unit will work. BUT!!! Most important!!! Check four big filter capacitors in the middle of unit!!!! If they are white (NAD 10000uF/80V) DO NOT USE UNIT AT ALL!!!! FIRE HAZARD!!!!! Contact me... Dariusz
    Dariusz70@verizon.net
    Posted on Feb 13, 2008
    520d
    1. Start the car
    2. While stationary, use the stalk "scroll" button and find the INIT icon. Push the stalk button.
    3. Start to drive
    4. The system initialises itself while you drive...
    Jul 12, 2014 | BMW Cars & Trucks
    Alarm activated and is unable to deactivate
    REMOTE KEY INITIALIZATION For this type of key.
    The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM V. The initialization procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
    Procedure:
    1. Close all doors and have all keys available.
    2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
    3. Within 30 seconds of turning the ignition switch to "off" Press and hold button #2 .
    4. While holding button #2 , press and release ("tap") button #1 three times within 10 seconds.
    5. Release both buttons. The LED in the key will flash momentarily. The GM will immediately lock and unlock the doors signalling a successful initialisation.
    6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
    7. Switching the ignition to KL R completes the initialisation.
    SERVICE NOTE:
    The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory functions activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
    REMOTE KEY INITIALISATION For this type of key.
    The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM. The initialisation procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
    Procedure:
    3. Within 30 seconds of turning the ignition switch to "off" Press and hold the arrow button.
    4. While holding the arrow button, press and release ("tap") the roundel button three times within 10 seconds.
    5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
    SERVICE NOTE:
    The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory function activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
    Apr 08, 2014 | 1996 BMW 540i
    My Air Force infared control 2 in 1 helicopter wont charge. (The light wont come up green)
    Found a previously posted solution here:
    http://www.fixya.com/support/t13972794-havoc_heli_won_39_t_charge
    1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
    Dec 25, 2013 | Spinmaster Air Hogs Red Defender Remote...
    My Havoc Heli won't charge
    http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
    Aug 12, 2012 | Spinmaster Air Hogs Red Defender Remote...
    Hi, The orange light in my canon ip1600 printer is blinking 5 times and green light once alternatively. Please give me a solution to fix it. What is the reason behind this problem? Thanks.
    Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    Jun 25, 2011 | Office Equipment & Supplies
    Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
    Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
    I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
    Hello.
    From Canon:
    3. Release RESUME
    Hope this helps.
    Dec 27, 2009 | Office Equipment & Supplies
    Remote is stuck in dvd 3 mode
    1. On your remote, push and hold "Enter"
    2. At the same time, push and hold "2"
    3. Keep them down for about 5 seconds
    4. Your remote should now work with the unit
    5. You can go to the set up menu and change the unit back to DVD3 if you wish, but you'll then need to repeat these steps using the "Enter" and "3" buttons
    Oct 08, 2008 | Sony RDR-VX525 DVD Recorder/VCR
    Hp laserjet 1320 problem
    This is an error state that is not described at HP site.
    Try to do a hard reset:
    1) Turn off the printer
    2) Press and hold down the green GO button
    3) Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
    4) Release the GO button.NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
    5) The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
    Hope it will help you
    Jan 24, 2008 | HP LaserJet 1320 Printer
    Spinmaster 3 wont light up
    the problem seems to be with the relay that switches on/off the lamp it seems not to be able to handle the current ant the contacts burn out... just check the side of the relay for melting/burning i have replaced mine with an uprated one with no probs
    Nov 27, 2007 | Office Equipment & Supplies
    87 people viewed this question
     Grubhead
    Grubhead
