Question about Dell OptiPlex GX260 PC Desktop
Missing power supply. First, thanks to fredtmccoyjr for the boot fix. the BIOS update from A06 to A09 actually allows me to enable boot from harddisk in the settings, instead of settign a useless tick on the menu. Heh... The toggles; they do nothing. Two of the other units I have lack working power supplies, and none of my spares are ATX-24/P4; but I do have spare ATX-28/cluster, ATX-20/P3 and a pile of matching BX backpanes. I can build an adaper to use either the ATX/blah units with some more information. I need to know does this model of Dell confirm to the 'standard' ATX pinout, or do I need to make a cardedge adaptor out of a spare backpane?
  • Darren Jul 06, 2010
    Thanks;
    6/17/2002 seemed a little close to the last time this bit me and I was not confident that the 4 pin molex connector took 12V and not 3V3. I can to do a continuity check to see which pins are ground and 5V to be certain about the main connector.
  • Dell Master
  • 5,660 Answers
It was the 1996 to 2000 time frame, that Dell was proprietary with the 20-pin ATX main power cable, and the matching connector on the mobo. (MOtherBOard).
Standard 20-pin ATX main power cable, and it's corresponding connector should work, then add the 4 power wires that are missing, in a separate connector.
To expound:
View this standard 20-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
The power wires should be in the same place as your P3 units.
(Match the color codes.
Use the lock tab on the 20-pin ATX main power cable connector, to base where the pins are.
Pins 1 though 20. Match the color code of the wires to the pins, and use the chart to compare)
Here is a view of a standard 24-pin ATX main power cable, and it's respective connector, so you can see what power wires are missing, from the 20-pin ATX main power cable connector, that are present in the 24-pin ATX main power cable connector.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the missing power wires, and what pins they line up with.
The P4, or also stated as the 4-pin ATX +12 Volt power cable, uses two Yellow (12 Volt) wires, and two Black wires, (Ground)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Since you don't have the male connector, be sure to orient in your mind where the Yellow (12 Volt) wires go, and the Black (Ground) wires go, by looking at the lock tab on the side of the female connector, on the motherboard, and comparing it to the photo.
Transfer this info, to the P4 connector you are going to make.
Where to get the power wires you need? Connect to any extra 4-pin Peripheral power cable wires, or splice off of ones that are in use, is one suggestion.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The links given are near the middle of the page. Scroll back to the top. Left-click on any power cable connector, that you wish more information on.
More info,
http://en.wikipedia.org/wiki/Computer_power_supply
Scroll to the bottom of the page, and look at the chart under the heading -
24-pin ATX12V 2.x power supply connector
(20-pin omits the last four: 11, 12, 23, and 24)
One more link,
http://www.smpspowersupply.com/connectors-pinouts.html
Lastly Dell Support > Optiplex GX260 > Service Manual,
http://support.dell.com/support/edocs/systems/opgx260/en/sm/index.htm
Just in case it's of any use.
Have questions regarding what I have stated, or need more clarification of anything I have stated, simply post in a Comment.
Posted on Jul 06, 2010
  • joecoolvette
    joecoolvette Jul 06, 2010
    Thank you for the rating Snow_Cat!
A03 checkpoint
Make sure that there is no power failure during bios update and you have a power back up of atleast 10-15 minutes. Download the update from Dell's website and double click on the .exe program. Wait for program to finish the job.
Nov 26, 2013 | Dell Dimension 3100 PC Desktop
Dell optiplex will not recognize hard drive
Is it SATA or IDE? Have you tried another cable? If it's IDE, have you checked the jumper settings (usually Cable Select is easiest)?
Feb 19, 2010 | Dell Optiplex GX60 PC Desktop
Put in new power supply, computer will not boot up. Asks what type of power supply, when I answer generic the computer will not continue to boot up. When I go into bios it says power supply is disabled and...
Try resetting the BIOS, depending on the motherboard, there will either be a button, switch or small jumpers that will short two pins and reset the cmos on the board. Just make sure to take out all the extra peripherals before powering back up. If you have jumpers, look for the one marked CMOS, not the one marked password. Move the jumper plug over one pin and power the system up. Wait approx. one minute and power back down, remove the power plug from the back and press the power button on the front to bleed off the power. Move the jumper back to its original place, plug the power cord back in and try booting the system back up. If it boots you will need to restart and get back into the BIOS and reset the time and date.
Jan 16, 2010 | HP Pavilion a420n PC Desktop
I can;t boot my laptop compaq Evo N610c from cd-rom drive
Disable the SATA option in BIOS settings then it automaticaly takes the CD ROM
Mar 04, 2009 | Compaq Evo N610C Notebook
Dell Optiplex GX260 desktop-how to reset factory settings in BIOS
sir try to remove the pill battery its in the inside of ur box that return it that might give an error said that u shud configure again ur time and date but that is easy but taht will increase teh speed and gives a reset to full factory defaults
Aug 13, 2008 | Dell OptiPlex GX260 PC Desktop
Optiplex 560 Power Intermittent
Try updating the BIOS. Seems there were some advanced power management improvements.
Dell Downloads
The following changes were made to the A04 BIOS for the A06 BIOS: 1) APM issues device commands in SMM. 2) Fixed APM to issue power up/down commands to peripherals in SMM. 3) Turbo/Deturbo switching done in SMM. 4) Implemented <\> Turbo/Deturbo hot key. 5) Password checked after exiting Setup and before OS booting. 6) Fixed the problem with #9 GXE64 Video card losing its video at the end of POST. 7) Fixed the problem with WINICU having General Protection Failures. 8) Fixed the problem with Real Time Clock not being updated correctly when in Power Managed mode.
May 15, 2008 | Dell OptiPlex GX260 PC Desktop
Dell optiplex wont boot up
If you are using a USB keyboard, then check in the bios that USB keyboard is enabled, and also Legacy support as well.
Legacy support will allow a USB keyboard to operate under the DOS environment.
This should allow you to press the any key to start booting from CD.
Hope that helps =)
Apr 13, 2008 | Computers & Internet
Dell OptiPlex GX260 PC Desktop Logo
225 people viewed this question
Alun Cox
