Question about Kitchen Appliances - Others
Franklin FIM350D 44lb outdoor ice maker will not make ice. Will not pump water over the ice cube tray. Water fills the reservoir but is not being pumped up to the tray. Should I replace the water pump or is it something else?
  • 1462 Answers
SOURCE: rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Posted on Jun 13, 2007
SOURCE: small ice cubes
The ice maker is time filled, it only has a certain time in which to fill. There is no way to adjust the water level. Check the pressure limiting valve which is in the water line before the filter. Have you replaced the filter? Remove the filter and pressure limiting valve and see if the ice maker receives more water. If it does, then replace the filter and check again. If it is still good, the pressure limiting valve is faulty.
Posted on Nov 03, 2007
  • 489 Answers
SOURCE: Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Posted on Apr 27, 2008
  • 172 Answers
SOURCE: Kenmore Refrigerator 106-9557612 Ice Maker won't Eject cubes
Hi caleycatz,
It sounds like you are in need of a motor module for your icemaker. This is the motor and gear that drives the icemaker prongs. The part number is
W10190935 The price is $77.59 and $6.00 shipping
I can have one of these at your door in 1-2 days, so let me know if you need one. We take Visa Mastercard and Discover. Or you can order from sears for the same price and wait 10 days.
Good luck to you and I really hope this will FixYa. Please take the time to rate me. Thanks
Mike Anerson (Owner)
Anderson Appliance Repair
(865)945-3808
Mca0824@aol.com
Posted on Oct 28, 2008
SOURCE: ice jams in KUIS18NNJB Kitchenaid under counter ice maker
There are 2 sets of wires on the cutting grid that are perpendicular to each other. Electrical current passing through the wires creates heat that melts the ice. The first set cuts one direction, then the ice strips drop onto the second set that cuts the strips into cubes. Remove the cutter grid and check if the wires are broken. If they are, electrical current can't pass through the wires, so no heat. Restringing kits are available to fix this. If the wires aren't broken, you'll need a voltmeter to see if current is reaching the wires. If it isn't, then the transformer has likely failed.
Posted on Mar 11, 2009
My ice maker does not make ice but water does run to front of fridge plz Help ????
I can't make out the words in your picture so there is not a lot of information to go on, but I will give it a try. If yours is like my refridgerator, there are a couple of off switches for the ice maker. One is on the control panel like the one you tried to photograph. Mine selects crushed ice, cubed ice, or ice off. The other soff switch is the lever switch that sits over the ice cube reservoir inside the freezer and shuts off the ice maker when the reservoir is full. If this lever switch is stuck in the up position you will make no ice. You say that water runs out of the front. Another problem that I once had with my ice maker was that the plastic housing around the ice cube tray cracked. One tray of ice cubes was made but when the ice maker flipped the tray over to expel the ice cubes the cracked plastic prevented any torque on the tray and the ice cubes would not come out. When the tray returned to the upright position new water would flow onto the tray, but since it was already full of ice cubes the water would simply overflow into the ice bucket reservoir. It did this over and over until I had an ice sculpture in my freezer and reservoir instead of ice cubes.
Jan 02, 2017 | Refrigerators
Ice maker on refrigerator does not work at all
Notwithstanding the ABSENCE of MAKE+MODEL...
(REFRIGERATER or ICEMAKER)...
Nothing came through with your "question"... ERGO
Most, generally & typically should be in front of everything that looks or sounds like a FACT.
Every ICE MAKER (I've ever worked on)has an on/off control...
Find it... turn it off, on, off & on several times (cycle the switch
(like lower the FILL wire ... or operate the on/off switch)).
ICE-MAKER heads are a relatively simple device with motor driven electro-mechanical sequencers that time water fill (adjustable), cube "done-ness" ((firmness by adjustable temperature)... and then "operate the fill valve... fill the tray...
Rotate the tray and eject the cubes.. refill with water...
If you can see or feel ice in your TRAY your...
you have NO ISSUE with your WATER VALVE...
To test this... use an ordinary water bottle and Put some water in your ICE TRAY...
Check back in an hour ...if your cubes have been NOT deposited into your ice bin... your ice-maker is turned off, has a open fuse or is defective & needs repair.
If it has ejected your cubes but you have not been refilled your WATER VALVE is defective...
replace it.
Hope this helps.
Aug 17, 2016 | Refrigerators
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
Freezer built up ice
This was answered on the page with the model number=>HERE
Model Numbers are easy to forget here but Very Important! Thanks, John Tripp Appliance 911
JENN-Air JFC2089HT
67006531 Water Inlet Valve
Jan 23, 2014 | Refrigerators
Jennair refrigerator jfc2089htb2
It is possible that the half side of your=> 67006531 Water Inlet Valve that controls water to ice maker is leaking like a dripping faucet and causing the problem. Can you see signs that water is flowing from the ice maker fill tube? The fill
JENN-Air JFC2089HT Water Inlet Valve Thanks John Tripp Appliance 911
Machine runs cold water but will not make ice, pump runs and everything else works.
Check the condenser coil to make sure it is cleaned out, also make sure the condenser fan is no dropping out. Next check to make sure the water fill valve is not seeping water past into the sump tray if so than it will not freeze, Water will get cold but not cold enough to freeze check water temp in sump tray with a thermometer to make sure it is getting down to 32 deg.
Oct 01, 2013 | Franklin Industries Franklin Chef FIM200...
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Kitchen Appliances - Others Logo
144 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
