Lg lh c6231 dvd/vcr switches to standby mode after short period Is that a problem with the amp ? or heating promlem in the amp unit ? thanks Thisan
  • thisan Jul 07, 2010
    The problem is in the LG LH-C6231 Home Theater system
    It will work for few minutes an swithed to standby mode.
    after few minutes whe I press the standby button It will swith on again and work for another 2minutes and again swithed to standby mode.
    Thanks
    Thisan
    Thanks
    Thisan
Your receiver is basically going into protect mode. Check your speaker cables. Make sure that all of them are seated properly and none is touching each other or the body of receiver. Take out all the wires and put them back in again. Even a tiny little frayed wire touching the receiver could trigger the protect mode. It is also posiible something is shorting out inside. A little frayed wire could also trigger the protect circuit in your receiver. You may have to open up the unit to replace a fuse or do some soldering. If you still have a warranty then send it in for repair. Something is overheating inside the amp
Posted on Jul 07, 2010
    Top Expert:
  • Audio Player... Master
  • 79,851 Answers
U have some kind of circuit failure in the amp, it is going to standby mode to prevent any further damage to the amplifier, you will need to either replace the unit or iget it diagnosed by a electronics repair shop, Radio Shop repairs these types of home electronics
  • 1,472 Answers
Thisan
When you mean a short time how long is a short time. Also long does it take before you can turn the receiver back on.
It sounds like you have a short on the receiver its self or another device is grounding back to the receiver.
The thing to keep in mind is with modern electronics they do not have a physical switch but they us contact switches. A contact switch works by making a connection to turn on or off.
The problem is if the an extra charge is being applied to the receiver this can cause the contact switch to engage.
To test this unplug all your connections to the receiver. Note most likely the speakers are not the problem so you do not need to disconnect them. However you do want to disconnect all connection including any HDMI cables. I had a case the other day where some on had a bad cable causing the problem. Next start plugging back in the devices to see which one is causing the problem.
If the receiver still turns off with all connection unpluged then the problem is with the receiver its self.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Jul 06, 2010
  • thisan Jul 06, 2010
    Hi
    Thanks
    Thisan
  • Will Hartford
    Will Hartford Jul 06, 2010
    thisan
    Just to confirm you did disconnect all the devices from the unit?
    If you did and you are not under warranty then you might open up the system to see if you can see anything not right. Note the first thing I would check is the fuse to make sure it is connected properly. The fuse can be a common problem because it is not in its clip fully it can cause shorts. The other thing I would look for would be bulging or leaking compositors as this is a sign of problems with the system.
    Also if you have not worked on electronics before you might get a friend that has to help you look over it.
    Let me know if you have any more problem or questions
    Issken
Does the lg lh-c62351 have facility to record from video to dvd
No. It is NOT a DVR to record on the DVD.
You can copy from DVD to VCR or
Record from video to VCR only.
Mar 27, 2016 | LG Televison & Video
Tip
LG LH-D6235 DVD Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Televison & Video
Tip
LG LH-D6235 Region Free Fix
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
LG CD/DVD Reciever unresponsive.
A lot of different equipment including but not limited to TV sets, computer towers you name it has this issue.
What I suspect is that if the unit has to be turned on several times before it works you have bad filter caps in the units power supply---standby supplies are on 7/24 if the unit is plugged in.
Look in the units power supply for puffed up caps that look like these.
Apr 03, 2012 | LG Televison & Video
I have a LG LH-T754 it is displaying "protection mode" how can I reset it? thanks
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 02, 2011 | LG LH-T754 Theater System
Have SANYO VCR/DVD Model E175216 and can't locate timer button for late night programming
Hi, if ithere is no button on the front of the unit or on the remote, then simply setting the unit to standby with either power button should make the unit enter the timer record mode. (This will be indicated with TIMER or a small red clock symbol in the display providing all the conditions have ben met. i..e clock & timer correctly set, tape in machine, etc)
Mar 16, 2010 | Sanyo DVW-5000 DVD Player/VCR
LG DVD Recorder- Clock settings Model RH277H
The clock settings will only be retained if you power down the unit via the On/Off button on the remote or on the unit i.e. put the unit into standby mode. If you switch off mains power the clock settings are lost as there is no backup battery in the unit. Power consumption on standby is negligible.
Dec 28, 2008 | LG RH299 DVD Recorder/VCR
LG LH C3603S
Ok thats easy just buy an s-video to rca cable and plug it into the dvd-vcr combo in the av in and then turn the vcr on to av 1 2 or 3 what ever you pluged it into then when that is all turned on and pluged in then you plug it into your laptop and wait it should switch over automaticly
Jun 22, 2008 | LG V194H DVD Player/VCR
LG LH-D6230 DVD
I had a similar problem coming from South Africa to Australia and had to change the regional code setting.
Change to multizone format:
1)Ensure no disk in unit
2)Unplug unit from AC supply
3)Plug unit back into ac supply
4)Use remote control for the following commands:
5)Press the power key, the unit will come on
6)Wait until no disk appears on the display
7)Press sequentially the keys: PAUSE;3;1;4;1;5;9
8) "Code" will appear on the display
9)Press 0 (multizone)
10 Press sequentially the keys: PAUSE,POWER
11)The unit will turn off(standby mode), leaving the new regional code programmed. If you do not succeed at the first attempt disconnect the unit and repeat the above steps (1 to 10)
Hop this helps
Susan
Jan 12, 2008 | LG LH-D6230 System
Receiver switches modes after a period of time
The actual switching is done by an electronic microprocessor. This electronic processor is most likely faulty by now, and needs to be replaced. Repair costs for this are expensive enough that buying a new receiver might be the best logical action, as a new comparable unit might cost only slightly more than the needed repair costs for the SA HE 200. Good luck.
Feb 26, 2007 | Panasonic SA-HE200 Receiver
Open Questions:
85 people viewed this question
 Grubhead
Grubhead
