Question about True GDM-7 Beverage Cooler
Thermostat does not go below 55 degree could it
Thermostat does not go below 55 degrees. Could it be its low on the refriderate coolant? (freeon) ? Other than the cooling temp problem everything else appears to be running ok
  • True Master
  • 8,220 Answers
You should clean them condenser coils and check the fan motor. That is something that is fairly easy to do. Get some coil cleaner from ace hardware and go by directions. Check that fan motor. If it ain't going while the compressor is going that is your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 05, 2010
1994 Buick Lesabre calls for a 160 or 180 degree thermostat
that is the opening temperature for the thermostat
it opens at 160 degrees which is good for hot weather operation or another with 180 degrees which is good for cold weather operations
The differences is 160 opens sooner to start coolant circulation to keep operating temperature low where the 180 keeps shut and allows the operating temperature to rise up as soon as it open the cold air will quickly cool the coolant.
Feb 28, 2015 | 1994 Buick LeSabre
Why does the temperature gauge on my 1995 Chevy K2500, 5.7L read 150 degrees ?
If you replaced the SENSOR and not the gauge SENDER, there's your answer.
The SENSOR sends the computer (ECM, PCM, ECU, etc.) the engine temp so it can make the adjustments to the fuel, timing etc.
The gauge SENDER makes the gauge read what temperature the engine coolant is.
Hope the helps.
Feb 21, 2015 | 1995 Chevrolet K2500
Po128 is the code. What's the problem
Well, I can't give you any specific information regarding your vehicle because you forgot to mention what kind of vehicle you have. (This is kinda important if you really want some help figuring out what is wrong with your car)
The "Generic OBD" of code P0128 is "Coolant Temperature Below Thermostat Regulating Temperature"
The most likely cause is a stuck-open thermostat, however, I have also seen defective Engine Coolant Temperature (ECT) sensors also cause this code.
Jun 13, 2011 | Chevrolet TrailBlazer Cars & Trucks
Temp gauge is in normal, 200 degree, range when starting. Within a few minutes of driving goes up to 250, right below orange line. No leaks found, coolant level appears fine. Any ideas?
250 DEGREES ENGINE GETTING TOO HOT.SOUND LIKE CLUTCH FAN FREEWHEEL.IF CLUTCH FAN DONT LOCK IN OR HAVE RESISTANCE TURNING BY HAND WHEN ENGINE HOT.FAN CLUTCH IS BAD.IF FAN CLUTCH OKAY COOLANT LEVEL CORRECT.I WOULD CHANGE THERMOSTAT FLUSH OUT ENGINE AND RADIATOR.IF ENGINE TEMPERATURE STILL READS 250 DEGREES OVER FLOW JUG OR RESERVOIR NOT BOILING OVER THE COOLANT TEMPERATURE SENSOR FAULTY.
Nov 05, 2010 | 2003 Chevrolet Avalanche
Refriderator side is nice and cold. Freezer side is hot 55 degrees. I have unplugged a couple of times but still won't lower the temp.
did you replace the fan on your unit? its not possible that the fridge is colder than freezer unless the fan is reverse..
Oct 01, 2010 | Refrigerators
Can you operate a refrigerator in a garage with out problems
Good day,
The high and low temperature range for a domestic refrigerator is 55 and 95 degrees. Above and below that issues will appear.
Above 95 degrees the compressor will be taxed badly, and will obviously shorten it's life.
Below 55 degrees it will not run enough to keep the freezer at decent temperatures, and because it stays off long periods of time, the oil in the compresser sump will thicken, making compressor starting difficult and once again shortening it's life.
It's done all the time but there is a cost long term.
Jul 13, 2010 | Kenmore 73503 Stainless Steel Bottom...
Self defrosting fridge/freezer
Good day,
That is normal if the room or area is too cold. If the room temperature drops below 55 degrees Fahrenheit then that problem will start to show up.
All manufacturers state the machine will start to unbalance below that temperature.
Mar 13, 2010 | Bosch Refrigerators
ASU9RLS/AOU9RLS unit Froze outside/ won't defrost
The drain had pine needles clogging the drainb so it couldn't drain.
In 2 months.... Thanks anyhow!
Jan 05, 2010 | Fujitsu Electronics - Others
I also want my air conditioner to cool to 55 degrees F or 12 C
12 degrees celcius equals 53.6 degrees Farenheit. You can have a unit hard wired but I don't recommend it. There are limitions to a\c units, they really shouldn't run if the outside temp is below 60 degrees.
Jun 08, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
True GDM-7 Beverage Cooler Logo
207 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
