Question about DCS BGA36-BQAR (LP) All-in-One Grill / Smoker
How do I remove the front panel to replace the sparker
I ordered a replacement spark generator, removed the two screws holding the panel in place. I also removed all knobs. the panel will move about a fraction of an inch but I cannot remove it completely.
    Champion:
  • 274 Answers
On some grills, the valves are also attached with screws to the front panel, these screw are removed and the front panel comes off. If this is not the case, you may have to unhook the gas line from the manifold.
Posted on Jul 12, 2010
Instructions for replacing the spark module on a DCS-305
In order to replace the Spark Module on your DCS-305, do the following:
  • 1
    Unplug the range from the wall outlet prior to servicing.
  • 2
    Remove the burner knobs from the burner switches on the front of the range. To remove the knobs, pull them straight away from the range. If the knobs are difficult to remove, wrap a piece of wire or string behind each knob for extra leverage.
  • 3
    Take off the bezel plate from each knob. Depending on the model of your range, this plate may be secured with screws, or the plate slides into place.
  • 4
    Remove the two screws that secure the valve panel then pull the panel off of the range. The spark module is now accessible for inspection, repair or replacement.
  • Oct 19, 2013 | Kitchen Ranges
    Viking model VGR48 stovetop burners will not ignite?
    First shut off the gas supply & disconnect electrical power to the range.
    • Remove all the burner control knobs, grates, burner caps & trim rings.
    • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
    • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
    • Place cardboard between each side of cooktop & bodyside to prevent damage.
    • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
    • Remove the wire from the electrode.
    • Remove the screw from the electrode mounting bracket to release the electrode.
    You can replace the electrode & reassemble following instructions in reverse order.
    Aug 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
    I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
    Good day Mr.james dant..
    Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
    Instructions
    1. Unplug the washing machine from the wall outlet
    2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
    3. Lift the dial off of the washing machine.
    4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
    6. Remove the wire harness from the old timer and remove the old timer
    7. Connect the wire harness to the new timer.
    8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
    9. Place the dial back onto the timer post and then screw the knob onto the post.
    10. Plug the washer back into the wall outlet
    Try to watch this video:
    Nov 25, 2011 | Washing Machines
    Remove_washing_machine_timer
    Remove back panel top.There should be 4 screws holding in the timer.Also the knob may have a small allen key screw holding it on.
    Oct 27, 2011 | Washing Machines
    How to remove dash panel to replace climate control panel
    1. Remove the instrument panel accessory trim plate around the control panel by prying gently and then pulling it straight out.
    2. Remove the control panel mounting screws.
    3. Pull the control panel straight out from the instrument panel.
    4. Disconnect the electrical connectors.
    5. Installation is the reverse order of removal.
    6. After installation, the actuators must be calibrated. For additional information, refer to the following section, -Actuator Calibration.-
    8. Fig. Remove the screw and pull the control panel straight out of the instrument panel.
    To calibrate the system:
    1. Place the ignition switch to the OFF position.
    2. Install the HVAC control module.
    3. Connect all previously disconnected components.
    4. Start the vehicle.
    5. Wait 40 seconds for the HVAC control module to self-calibrate.
    6. Verify that no DTCs have set as current DTCs.
    7. Place the ignition switch to the OFF position.
    8. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
    9. Rotate the Mode knob fully counterclockwise.
    10. Rotate the Mode knob fully clockwise.
    11. Rotate the Mode knob fully counterclockwise.
    12. Release the AC button.
    13. Wait 40 seconds for the HVAC control module to self-calibrate.
    14. Start the vehicle.
    Sep 14, 2011 | 2001 Oldsmobile Silhouette
    When I go to start my grill, I turn on the gas and then the knob on the right side to spark the gas for the fire. When I turn the knob it does not spark the gas. Hoe do I troubleshoot what is wrong....
    It sounds like you have a rotary piezo igniter, which means you get one click, or spark, per rotation. If there is no click when you turn the knob, or the knob spins freely when you turn it, it has probably broken. If you pull the knob of, there should be two screws behind the knob that holds the igniter to the front panel. Hopefully you can remove the screws and reach behind the panel to remove the igniter. If this wont work, you have to remove the front panel. If the igniter is not broken, then check the wires and electrode for shorts.
    Jul 03, 2011 | Ducane 1005A (LP) Grill
    How do you get to the fan on the generation 3 kirby
    First remove the handle, next remove the screws attaching the cord, and switch trim plate. The small screw and knob on the handle pivot must be removed to remove the switch trim piece - insert a flat screwdriver into the small slot in the plastic and pop the trim off to expose the rear motor shell screws. Remove the four screws holding the upper motor shell in place to expose the fan housing screws. Remove the five screws holding the fan housing in place, noting their positions. Pry the fan housing off to expose the fan. Hold the fan in place while turning the belt pulley CLOCKWISE to remove it. If the armature turns, it must be held in place with an open end wrench (about 9mm). There are flat spots on the armature just in front of the commutator bars. Pull or pry the fan and associated washer off the armature shaft. After replacing the fan and pulley, put a bead of silicon sealant on the fan housing and replace all parts in reverse order of removing.
    Dec 01, 2010 | Kirby Generation 3 Bagged Upright Vacuum
    I have a ducane stainless steel ducane 30400042. Weber has sent me new burner bars since the old ones rusted but you do I install them?
    Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
    ****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
    Jun 20, 2009 | Ducane 30400040 Stainless Steel Grill
    How to change the burners
    Mar 30, 2009 | Ducane 30400040 Stainless Steel Grill
    Replace burners
    remove the cooking grates and the 5 pieces ubnder the grates covering the burners from the grill. Next remove the 4 screws on either side of the control knob panel pull it away from grill and pull the burners out from inside the grill. DO the reverse to install new burners
    Apr 19, 2008 | Ducane 30400042 (LP)
    DCS BGA36-BQAR (LP) All-in-One Grill / Smoker Logo
    326 people viewed this question
    Top DCS Grilling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Johnny Kendrick
    Johnny Kendrick
    Level 1 Expert
    Are you a DCS Grilling Expert? Answer questions, earn points and help others
