Question about Dell Inspiron 1200 14.1 XGA LCD Display-320-4222 (3204222) CD-ROM Drive
My dell inspiron 1200 does not seem to hibernate or have a standby mode. The standby mode is not highlighted as an option when I go to the shutdown/restart screen. When I close the laptop it doesn't turn off, but when I open the computer it won't turn back on.
  • tonyamurphy0 Jul 06, 2010
    I've done that. I think the problem may have to do with my monitor. After I've shut my laptop, when I open it the monitor stays black. Also, standby is grayed out when I look at the shutdown screen.
  • tonyamurphy0 Jul 07, 2010
    Thanks for trying to help me, but I've done a ton of stuff in the power options field and none of it seems to help. I'm wondering if it's something with my monitor. The monitor goes dark after I shut the laptop, but then doesn't come back up when I reopen. I've tried all types of awake, hibernate or standby options and it doesn't work. Also, standby is not an option when I try to shutdown or restart.
    Genius:
  • 1,189 Answers
  • Hi, you can go into the "Control Panel" and make changes to the Power Saving Options, or Energy Saving. First from the "Start Menu" in the [Start Search] window, type: power, next scroll to find the "Short-cut' listing for {Power Options}, click on it to go to the next window. You'll be able to adjust the "Power Options," (Sleep, "Awake," or Hiberate, if available). "Let me know how things worked out for you by giving a "helpful rating"
Posted on Jul 05, 2010
  • paul7of9
    paul7of9 Jul 06, 2010
    Jul 06, 2010 - by Paul7fo9 - Hi, I just want to thank you for taking the time to come back, and give your Helpful Rating; I just wish more people like you would do the same, especially if they get a chance to express their frustration to the problem they might be dealing with. I think of it as therapy; not reward!"
When i hibernate, my computer turns back on in 30 seconds/
check that it is not set to 'wake on wifi', if so, turn this setting off
Oct 19, 2012 | Dell Inspiron 1200 Notebook
Dell Inspiron going to hibernate when its not set on hibernate
The hibernate mode is one of microsoft's worst idea because it often corruped window files forcing the user to reload windows from scratch. When you were in power options did you also turn off standby? and set it to never on the list.
Apr 27, 2012 | Dell Inspiron 15R Laptop
My computer is booting then after short time it return to standby mode then the fan of processor rotate at very high speed and signal is remove from monitor
Seems like the PC has Hibernation mode turned on. After 1 hour windows will put the PC and hardrives to sleep to conserve power. If you want to disable it, here how:
  1. Open Control Panel.
  2. Double-click the Power Options icon.
  3. Within the Power Options Properties window, click the Hibernate tab.
  4. Uncheck the "Enable hibernation" checkbox to disable the feature, or check the box to enable it. This window also displays the total space required for hibernation.
Sep 19, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I have a Dell Inspiron 1200. The standby option
Go to the power option and select Laptop power schemes. Restart the computer that should fix the issue.
Thanks
Jul 06, 2010 | Dell Inspiron 1200 Notebook
My dell inspiron E1405 screen turns off by itself it turns on fine but after a couple min. The screen turns off but the laptop is still on
Its going to sleep mode after 5 mins or going to standby if you are not working on it. you can on it by moving mouse or pressing any key on keyboard if it gone to sleep mode .You can press power button to make it on if its gone to standby. To disable this Right click on any empty space on desktop and go to screen saver tab and click on Power button . There in Power Scheme tab , make all options to NEVER and press Apply and OK.Now it will work fine. Options are turnoff monitor, turn off hard disk , System standby , system hibernates etc
Feb 17, 2010 | Dell Inspiron E1405 Notebook
How do i re-activate hibernate and standby on my dell inspiron 6400. both used to be available but after having it repaired i can't seem to find a way to reactivate them
Type cmd into the start menu search box, and use Ctrl+Shift+Enter to open in administrator mode. You can also right-click the item in the menu and choose Run as Administrator. From the command prompt window type the following command
powercfg /hibernate on
restart your computer and it will take effect.
Dec 19, 2009 | Dell Inspiron 6400 Notebook
When I take the computer out of the standby mode
Try this:
  1. Update the BIOS and Video driver to the most current on http://support.dell.com
  2. Disable the screen saver
  3. Enable HIBERNATE instead of standby in Power settings, set the LCD to go off in 10 minutes, HDD to 15 and Hibernate in 20.
Select Shutdown, Hibernate
then try and restart
If no GO, disconnect all peripheral items except KB
Try hibernate again and restart.
If all works OK, add items back one at a time till you find item causing issue. If no go, replace power supply if issue still occurs, replace MB
Oct 13, 2009 | Dell Inspiron 530 Desktop Computer
Inspiron 1200 "Fatal Error" , cannot F8 into safe mode
Press "F8" while booting up. It should give you an option to go to safe mode.
Jun 29, 2009 | Dell Inspiron 1200 14.1 XGA LCD...
Doesnot enter standby mode and hibernate mode
hy quick fix go to the web sit and get updates on all mother board soft wair and go 2 my computer propetys and check se if thay are any yellow highlights you will be able 2 solve that way2 good luck plumdj
Oct 08, 2008 | Compaq Presario X1000 Notebook
Where is the Sleep Button to put D-I'n-1000 into hibernation
There is no SLEEP BUTTON per se on and Inspiron 1000 system.
Enabling Hibernate is easy enough though. Go to Control Panel, POWER OPTIONS. In the power options window, click the hibernate tab and ensure the ENABLE HIBERNATION checkbox is checked., then click the ADVANCED TAB. Look for the "When I close the lid of my computer option and select HIBERNATE.
Since that system doesn't have a SLEEP BUTTON, that option may be listed, but is of no use.
Hee is a link to the I1000 manual
http://support.dell.com/support/edocs/systems/ins1000/en/Y69601LRs.pdf
Jul 19, 2008 | Dell Inspiron 1000 Notebook
Computers & Internet Logo
209 people viewed this question
Alun Cox
