Question about Creative Labs WebCam Live!
My web cam doesn't focus. Only on my screen is it in focus but on other screens it is out of focus. What can I do?
Emachines e627 web cam problem
Could be a simply focus adjustment within the cam software that needs to be done. Or the cam is bad itself try adjusting the focus wheel as well. It may be out of focus. Usually the adjustment is on the lens turn it in or out. Try testing the cam on another computer close by see if it is working well on another computer. If not replace the cam. Try re installing the cam software and driver files. John
Apr 20, 2012 | eMachines E620-5885 Notebook
How do i use my built in webcam to take and upload pics?
its a little harder to upload photos on a web cam that is mounted on the laptop as in order to keep them in focus they are generally set for a 2-3 ft away focus plane. Although still possible you would need to hold the photo steady at that distance and create a still image. At any rate this image will only be as good as your web cams resolution, so a scan is a much better photo way to transfer and wont have the bad background around it like the web cam photo. A scan will help you crop it too.
as for the actual use of the web cam you will have a program that you need to launch. Skype.com has its own program and you are able to take photos with it and communicate live as well. go through your programs list on the left hand corner of your screen choose Start, Programs, and look through them one by one until you get one that has the web cam program. if none of them do get the skype and try it instead.
Jun 13, 2011 | Computers & Internet
My web cam is Screen black
try to put focus the lens by turning it around till you find images , if that is not to your please go to the web cam icon and set it up from there
by setting the color the white balance
Aug 04, 2009 | Acer Extensa 4620 Notebook
Video picture is not clear on webcam. Picture is not focused. How do I correct the blurred image seen by the webcam?
Most web cams have a short focal range, (Nearest to furthest focused content), and have a front lens that turns like a dial so you can choose where you want your camera to focus.
Try Twisiting the housing or ring around the front lens, if it turns then turn it while viewing the image on the computer to set the focus where you like.
Also make shure there are NO smudges on the lens, it's small so even the tinyest smudge or spec is huge on the screen.
Jun 18, 2009 | Philips SPC230NC Webcam
Logitech web cam is blurry
somewhere on the camera there will be a focus knob, usually it is the housing just outside the lens that your fingers can grab hold of. she need to turn it until it comes to focus
Apr 23, 2009 | Logitech Webcam
Blurry picture
There is a focus ring around the lens of the WEB cam turn this ring until your image becomes clear, just like a camera focus knob.
Click on the WEB cam software, you will be able to go into an options or configuration, click on video setting, you should see an image of yourself, adjust the focus until the image is clear.
Jan 01, 2009 | Radio Shack VGA PC Camera Webcam
The only thing that i see when i use my webcam is a black screen. also whr i start to chat, people can only see a black screen.
that's because you need to focus the cam. start turning the black dial clockwise until you can see the image in focus. it will take quite a few turns to see a difference. if you turn it like 10-15 times and there still isn't a difference, try turning it the other way about 25 times. hope this helps!!!!
Nov 29, 2008 | Microsoft LifeCam VX-3000 Web Camera
Web cam(Yu cam) problem in HP Pavilion dv6000 notebook pc
go to web cam manufactures page and look for upgrade software and drivers.
Nov 10, 2008 | HP Pavilion dv6000z Notebook
Web cam
I suggest that you focus the lens.
On your web cam,where the lens is, can you move/turn a little wheel?
This is the focus wheel.
Or you could try in the webcams settings.
Hope Ive Helped.
Regards,
Sophie x
Feb 14, 2008 | Logitech Webcam
Creative Labs WebCam Live! Logo
18 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
