Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
No ignition flip switch the starter clicks but there in no ignition help
    Scholar:
  • 78 Answers
First male sure all the gas valves are open. (supply line, heater, etc.) Make sure gas pressure is correct. Check the pilot orifice to ensure it is not clogged. Check for 24 VAC at gas valve from the PC board. If voltage is present at the gas valve terminals, I would say a bad valve. No voltage, bad PC board. I would check the first items initially.
Posted on Jul 06, 2010
Hi, my ssanyong Rexton, the battery is fine but the engine does not startup, tried many jump starters still cannot start.. What is the solution?
Does the starter spin the motor? IF not, you can bypass the starter circuit by directly connecting a jumper from your battery (positive terminal) to the smaller of the three starter terminals. It will be located on the solenoid. First disconnect the coil pack so the car won't start. Next connect the jumper to the starter first, then the battery, flip the jumper switch, You should hear a loud click and the starter should spin the motor. If the starter spins the motor immediately flip the switch back to "open", disconnect the jumper as your problem lies elsewhere. If starter doesn't spin, the starter/solenoid is the problem. If it does spin the motor, you may have a bad wire, fuse, ignition switch, terminal connection etc. If you are uncomfortable with this solution, take it to a technician. Any of them should be able to diagnose the problem.
Feb 09, 2017 | Cars & Trucks
This is a Troy Bilt Big Red Horse Tiller. Wont crank. new battery. ignition switch good. starter relay clicks when ignition switch turned. jumpering the relay makes the starter spin.
The starter solenoid/relay clicking can mean a bad starter solenoid/relay or bad grounding. Not knowing what engine you have as they have used Kohler, Tecumseh and Briggs and Stratton over the years. hope this helps
Mar 06, 2015 | Troy-Bilt Garden
My Battery is Good but when i turn it on no Clicking or turn over I Have Lights tho Whats the Problem?? HELP!!
Bad ignition switch, or starter motor or solenoid.
No clicking noise points to ignition switch isn't getting the juice to the solenoid (which is the thing that makes the clicking and allows the starter motor to engage the flywheel).
Jiggle around the key in the ignition and pull on the wiring harness a little. If you get it to start then you know the problem is in the switch or the wiring to the starter solenoid
Mar 06, 2015 | Cars & Trucks
No start just clicks at starter 2002 flhtci
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a possible prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 05, 2014 | Harley Davidson FLHT Electra Glide...
Starter wont spin using key but will by using a jumper from the battery
the ignition switch is bad that the part where u put the key in
Jan 30, 2013 | 1994 Ford Escort
Sometimes it won't start, just clicks. replaced the starter and the battery. power gets to the starter, so don't think it's the ignition switch.
if your power going to starter from ignition switch ,your starter has to be faulty or main wires on starter has bad connection
Sep 07, 2011 | 2001 Suzuki Grand Vitara
1999 Isuzu Amigo V6 2wd: Car doesn't start always. Turn the key, lights come on, radio on, etc, but no clicking noise, no engine trying to turn over, absolutely nothing. I put in a new battery, but same...
When I have such a problem with my Toyota pickup, I install a button in dash to crank the motor over. Hot wire from the switch on to the button, then from the button to the starter activating wire. My Toy doesn't do this every time, but when it won't crank I just reach down and flip the spring center switch, same as a button, and she cranks and fires up. This is easier than replacing a bunch of stuff that may not be bad or is impossible to get to.
May 26, 2017 | 1999 Isuzu Amigo
Changed ignigtion on presitge remote starter now it wont work
Put the key in the ignition turn it to the run or on position, then find the valet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you need to press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds. After that turn the ignition switch off and remove your key. Try the remote to see if it works the way it should if not, call 1-800-225-5074 tech support
Jan 15, 2010 | Prestige 2 Button Remote Security System...
1995 nissan maxima doesnt start when cold, just clicks, and after trying for 5 to 10 minutes it finally starts... Please help me out...
it is one of two things.
  • the starter is either worn and brushes not making contact or an engine oil leak onto the starter. thus keeping the brushes from making contact you can check this by banging on the starter while someone trys turning the ignition back and forth to start.(making the click click click)
  • ignition switch is weak, not providing enough voltage from the to kick the soliniod all the way to start the starter
The way to check that is to hot wire the starter soliniod little wire, to battery voltage. (the big cable on the solinoid)
If it turns over good, then you can either replace the ignition switch or install a relay someware near the starter to supply it with propper current to kick the solinoid all the way to engage the motor.
The relay acts as a remote starter switch that feeds more direct power to the starter solinoid.Now the only thing the ignition switch is responsible for, is trigger the relay.
Oct 31, 2009 | 1997 Nissan Maxima
Starts but quits as soon as key returns to run position.
My bet is that you have an open the fuel pump run circuit or the vacuum switch. Most GMs have a vacuum switch to 'see' the engine running and reduce pressure by cutting voltage. However, if your car has a turbo or supercharger, they use a relay that 'flips' to a resistive line which then cuts the power level to the pump. Get a good model-specific diagram and check it out.
Jul 23, 2008 | 2003 Pontiac Sunfire
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
89 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
