Question about JVC KD-G120 CD Player
Which color is the memory wire im tired of resetting time and audio configurations plz help
  • 92 Answers
Basically you have a power wire which should be wired to a switched connection and a memory wire which should be wired to a unswiched connection. look on your fuse box under the dash and connect the power wire first to a switched fuse (one that shuts off the radio when you turn off key) then look for a fuse (with same power wire )that when you turn off the key the radio stays on, this is the fuse that you connect the memory to,or you can connect the memory wire directly to the battery but you must use an inline fuse or you burn up your radio,car etc.
Posted on Jul 06, 2010
I dont know what wires go with what for my memory harness
modified-life-logo.gif.com gives out free diagrams for stereo installs check it out helped me out now im spreading the word..
May 11, 2010 | Pioneer DEH-P2900MP CD Receiver...
Im trying to wire my radio to my car, but the colors on the inside of my car are different to the ones Im acustomed to...plz help
No mater what color sceme you have the wires all play the same roll. Ground/ power/ common. B/W , Red, Yellow, purple/wh, brown , some cases blue, blue /wh and green. Check all wires for power on and off circuit with test light. black to ground - side speaker rd to + side etc;
Mar 04, 2010 | Car Audio & Video
Every time i turn off my car all my audio settings reset.
check and see if the ;yellow wire is connected to a constant power source.
Jan 06, 2010 | Nesa Vision NSD-790T Car DVD Player
Memory Module & hardware conflict
Dear Sir
Please try latest service pack from net and check. Some hardware devices are not compatiable.
Mar 12, 2009 | Toshiba ZA2000P02 - Satellite...
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
No memory
check to make sure you don't have the batt+ wire and switched 12v wire mixed up. batt+ is usually yellow or orange while the switched 12v wire is usually red, consult the manual or look on the unit itself. there should be a wire color description there. batt+ is what you want 12v running to all the time to keep the settings. switched 12v is the one that turns the unit on when the key is turned on. the unit will still operate if the 2 are backwards but like you said it will clear the memory every time you shut it off because your cutting power to the batt+ wire thus resetting the unit.
Feb 17, 2009 | JVC KD-PDR30 CD Player
Powered subwoofer wiring
Red = 12v power Always
Black = Ground Allways
Blue = memory wire that has to run to a Amplifiers Memory Terminal
2x White, seems to be the dimmer and Ant, but im unsure as of these two,
Rca's will go into the AUDIO out of the cd player RED and White holes, that will go to your amplifier.
Im unsure if your talking about a Cd player here, but it seems this it is. If so you should have color coded wires for speakers also (ex- green, green with white stripe, Yellow, yellow with white stripe )
Please provide more information if this dosent solve your problem
Thank you
Sep 11, 2008 | Sony CDX-M610 CD Player
Wiring
Here you go:
[POWER]
Red: 12 Volt switched
Yellow: 12 Volt Constant (FULL TIME FOR SETTINGS MEMORY RETENTION)
Black: Common ground
IF YOU HAVE AN ORANGE, it is for DASH BOARD lighting sense to dim the radio similar to the stock radio. (Best if snugly covered and isolated. and not used.)
Blue: System Power on sense for any amplifiers, also known as "P.CONT.", "rem.", or "remote wire"
Blue White: Power antenna up/down
[FRONT SPEAKERS]
White: Left Speaker POSITIVE (+)
White Black: Left Speaker NEGATIVE (-)
Grey: Right Speaker POSITIVE (+)
Grey Black: Right Speaker NEGATIVE(-)
[REAR SPEAKERS]
Violet: Left Rear POSITIVE (+)
Violet Black: Left Rear NEGATIVE (-)
Green: Right Rear POSITIVE (+)
Green Black: Right Rear NEGATIVE (-)
Aug 03, 2008 | Pioneer DEH-P4800MP CD Player
Installing Alpine CDE-9852 CD Reciever In A Ford Mercury Sable LS
well most commen tool is a phillips head screw driver (+) to remove components to get the old deck out you'll need a dash kit to mount the new radio in 15 buck from canadian tire or audio shop...
the easyest way to wire this up would be getting a harness to plug into the factory harness too get the color code and then u just make the connections red to red yellow to yellow makes it real simple that way... the other way is to get the hanes manual for your vehicle then find out what color each wire is then yu have to cut the factory harness wire up from the book takes alot longer but can be done its worth the 12-20 dollars to get the job done if you need more help ask
Apr 21, 2008 | Alpine CDE-9852 CD Player
JVC KD-G120 CD Player Logo
599 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
