Question about Maytag MFI2266AES Stainless Steel Bottom Freezer French Door Refrigerator
Left freezer open for 4 days
Does the fridge have any protection for this? ie: does the condenser still run if the door is open for a long period of time?
  • 619 Answers
Yes. Every thing will run and the only time unit will shut off is when it reached auto defrost. Door open will just not let temps reach normal ranges. There is no protection for this.
Posted on Jul 05, 2010
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Water is puddeling under the left side and front of the fridge. its dry and dusty underneath. water line for ice maker has been disconnected for years. cant figure where the water is coming from
You have a side by side or a undermounted freezer? I am having the same problem with mine. Take a look into the bottom of the freezer, there is probably ice building up on the bottom of it under the bottom self or basket. It seems if the refrigerator door is opened frequently and it is moderately or very humid in your home the water vapour condences inside the freezer. There is probably a condensation tray somewhere that is overflowing into the freezer compartment. Once the ice build up on the bottom gets to a certain point the water then starts to run out the front of the fridge onto the floor. Remove the ice from the bottom of the fridge and empty the condensation tray. You may have to continually do this during humid periods. For me that is about 6 months of the year every 3 to 4 days. It's a pain but what are you going to do.
Oct 15, 2015 | Refrigerators
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
Hello. My freezer part of my subzero 690 is getting too cold. The temperature has dropped to -8. My normal setting is zero. I tried raising the setting to +5 with no effect. I tried turning the whole...
check u tube for problem solving videos.
There are a number of great troubleshooting u tube videos, which show you what to look for and many of the fixes are really simple and are universal for all fridges. The simplest is that you left a door open, moisture got in and froze causing ice to build up, so you have to thaw it totally, not just turn it off. I moved my older subzero and think one of the tubes must have been knocked and it lost its Freon, so stopped cooling. The cost of having it recharged was so prohibitive (ie environmental disposal issue meant it had to be moved to a special location fixed and moved back at my expense or Subzero said it was a closed unit and you had to replace the whole thing$ 1,300 for the condenser alone) so, I tossed it + bought another used one until my renovation was done.
Generally with any fridge, there seems to be 2 possible Simple reasons:
1. DEFROST MODE PROBLEM it is stuck in defrost mode
. a)the defrosting tube is plugged
b)The tube or thermostat is frozen, most likely because someone left the door open or the seal is poor;
c) termostat defective-untube video explained how to test circuit;
4. CONDENSER ISSUES: the condenser coolant gas is low and can be easily recharged- see the u tube how to video;
5. Condenser is dirty and cannot breathe- vacuum it;
6. The condenser overheated and needs replacing . 4-6 will have the condenser blowing cool not warm air.
I have had this problem with the fridge portion of my SUBZERO bottom freezer and Subzero (and a repair person ) gave me some good advice, which should also apply to yours, but you might want to call them yourself:
1. Simplest fix- if the defrost tube is blocked or frozen, the defrost cycle will stick on preventing cooling (either freezing up or heating for the defrost cycle not cooling); Some subzero models are especially prone to this. I could see part of my tube inside the fridge on the back wall close to the bottom where it drains and removed the panels to expose and clean it;
2. You should pull it out and unplug it to get it to defrost fully. After doing that once, I made sure my fridge was on a separate circuit or switched!! Yours might not be the same, but on mine the tubes run through the fridge to get to the freezer so both parts have to defrost;
3. Subzero fridge and freezer each have their own independent condensers, so you might be hearing the condenser for the fridge running, even though one part is turned off.
4. Check the thermostat to see if it is working. There is a good u tube video on this.
5 Some of the u tube videos show how to "recharge" the Freon. Subzero told me these are sealed units and could not be done, so regardless of the problem, the condenser had to be replaced. The subzero repair person was really helpful + checked the Freon or gas level (Mine was old enough that it was Freon not the newer environmental stuff) so they would have to haul it away to drain and recharge it + then the condenser might still have to be replaced.
Good luck
Joan
Jan 15, 2011 | Sub-Zero 690 Side by Side Refrigerator
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Condensation on the strip between the 2 french doors
these fridge have a heater in that black flaper to prevent condensation. It is probably not working or not even plugged...do they removed the doors when they delivered your fridge??? remove the uper left cap of the hinge, the connection is there...... the tech must check that piece if it is well plugged..
Jul 03, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Fridge not cooling
hi there.
welcome to fixya.
initially try to defrost the ref and clean it.
Feb 26, 2009 | Amana ASB 2623 Side by Side Refrigerator
Maytag MFI2266AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
101 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
