Question about Husqvarna 26 Hp 54" Deck Zero Turn Riding Mower
Mower starts, but won't move forward. I found torn belt underneath. I'm assuming this is a drive belt (are there two--one for each wheel). How do I change it out. (Best way to lift a zero turn?).
  • Anonymous Mar 15, 2014
    I put the mower in drive but it would move. When i pushed it to move it i found a bolt and washer underneath. Where does it belong ??
    Novelist:
  • 146 Answers
First, wedge something in front of the front wheels (when you lift the back, there's no brake action). Get the jack from your car and position it to lift the rear of the mower chassis. Jack it up then put blocks under the rear wheels - you may be able to do both at once, or you may have to alternate - then lower onto the blocks. Get enough space. You'll have to take off the mower belt and remove the PTO clutch anchor (two bolts) and may have to take off the wires connected to the PTO clutch (connector may be above the chassis). Then pull off the spring that tightens the idler arm, remove the old belt (if it's still there) and install the new one. Refasten the spring to tighten the idler, replace the anchor and mower belt, and mow away. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 06, 2010
Why won,t my toro z4200 zero turn mower go forward or back model#74360
Hi there, I assume the motor runs as usual, and doesn't cut out when you try to move forward or back. That would be a different problem than what I'm thinking about now:
If you look underneath at the transmission belt (this usually goes from the motor pulley to the rear transmission / diff) and see if it has fallen off a pulley, or disappeared completely. This would stop the forward or reverse drive of the mower. If this is the case, a new belt should solve your problem.
Jun 12, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Why isn't Lawnboy lawn mower model NO. 10604 drive not working
Inspect the pulley where the belt loops on the wheel transmission. There is a tension spring, that when you pull the level, it puts tension on the belt. If that spring is missing or the pulley does not provide tension the wheels will not turn because the transmission is not being engaed..
May 23, 2014 | Heavy Machinery
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
Lawnmower wheels won't drive
If its a riding mower it probably the drive belts off track or slung off. The mower will still start up and turn blades with the drive belt off, but want engage to go forward or reverse if this is the problem.
Aug 17, 2013 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I have a 42" Craftsman
HI IF YOUR BELT IS LOOSE THEN YES YOU NEED A NEW BELT
IT IS A V-BELT GROUND DRIVE-95 25
PART /160855
Sep 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Self propelled feature stopped functining. I previously replaced the wheels after the gears had worn down. Now I can't get any response to engaging the self-propelled cable.
Have you checked the drive belt? There should be a belt running from the main shaft (above blade) out to the wheel drive. You didn't list model number but I'm assuming it's front wheel drive. There should be a cover over this belt so it might be hard to see from underneath. Also there should be a cover on top going to the drive transmission. If the belt is OK, check to be sure lever is moving the transmission lever.
Oct 30, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman model 917.271814 will not go forward or reverse. Heard a "click" and mower stopped moving; engine and blade still running.
Check the drive belt that runs back to the transaxle,it sounds like it broke.If the belt is in the pulley check to see if the transaxle pulley is turning when the clutch is out.Also make sure both wheel axle keys are in the rear wheels.If all this checks out the transaxle may have broke,look underneath to see if it is broken there.
Aug 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna 26 Hp 54" Deck Zero Turn Riding Mower Logo
611 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
