Question about ASUS P5K-V - Motherboard - ATX - iG33 - LGA775 Socket - UDMA133, Serial ATA-300 , eSATA - Giga...
I have a asus P5K motherboard, 4gb Patriot mem., and a duo 6700 processor.I was installing a additional HD , my problem occurred when I turn the system off during reboot. Now when I turn the system on fans run green light on the MB, CPU runs. Now there isn't a signal to the monitor- not even the bios, and I can not turnthe unit off except with the switch on the PS. I reset system, reset memory, disconnected HD's, even changed HD, without any luck.
    Guru:
  • 528 Answers
Hi. here are possible troubleshootign steps to resolved this issue.
1) Kind of obvious) Switch all off and try again.
Switch off the power at the PSU (switch on back), then hold down the ATX switch (on button on the front of the case) for 30 seconds to clear residual charge in capacitors. Switch back on. - If this worked you really didn't need this FAQ...
2) Ensure that ALL cables are tight, pay special attention to the dongle going to the GFX card (if applicable).
Also make sure that your monitor is actually plugged in to your GFX card...
3) Reseat the GFX card, take it out, check for obvious signs of damage, you may want to clean the gold contacts with alcohol or meths.
Put a small amount on a "lint-free" tissue, or use coffee filters.
Put it back in. Make sure it's all the way in and nice and tight.
You should just be able to see the very tops of the gold contacts sticking out of the socket. Make sure that there's nothing obstructing it - e.g. open RAM clips on the motherboard.
If there are any clips to lock it down make sure they are tight.
4) Clear the CMOS.
The CMOS battery provides charge when there is no power at all going to your motherboard; this charge keeps the adjustable settings of your BIOS set. Clearing these settings resets you BIOS.
If you have one, use the clear CMOS jumper located near the battery on your motherboard. Get exact details in your motherboard manual, but basically it's three pins, with a jumper over two of them
With power switched off as in step 1, move the jumper to short the other pin
leave for about 5seconds then put back, switch power back on.
If you do not have a clear CMOS jumper, remove the CMOS battery. The battery's a pretty easy thing to spot. It looks like a watch battery... To remove it, look for the little clip holding it down towards one edge, push it back so that the battery "pops up" (Tooth-pick is a useful tool for this - Do not use a screwdriver or force the battery in anyway.). Once it's out, place it on a nonconductive, clean, and surface. Try to hold the battery by the edges if possible.
Leave for about 30 minutes then put back in. Switch on.
Posted on Jul 05, 2010
  • radman356 Jul 06, 2010
    I have retried the suggestions and failed, status of MB is the same. I am ready for another idea, I
    have read where others have had the same problems with this series of MB from Asus, but without any answers.
P5k-e front pannel audio not working
Make sure you check that the front audio cable is connected properly on your motherboard. You can see how it's supposed to be hooked up and where it is located on page 2-32 in either of the manuals I have linked up for you below. And if you haven't already make sure you have the correct audio driver installed.
Drivers & Downloads for ASUS P5K-E/WIFI-AP:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KEWIFIAP/#download
Manual #1:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3216_p5k-e.zip
Manual#2:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3501_p5k-e_wifi-ap.zip
Jun 14, 2012 | ASUSTeK COMPUTER Asus P5k-e/wifi-ap Lga775...
Does p5k se motherboard support with GTX460 ?
If you are talking about the Nvidia Geforce gtx 460 video card working with the Asus p5k se motherboard?! YES!! That motherboard should have a pci-e 2.0 x16 expansion slot with is what this video card needs.
Hope this helps!
Jan 23, 2011 | ASUS P5K SE MOTHERBOARD (4719543152829)
My asus m2n32-sli motherboard won't start up; runs for 4 seconds then shuts off. currently hooked up to the mobo: have a 500W power supply; AMD 3300 64 processor; zalman cpu fan; 2 patriot 2GB DDR2...
The only thing i can suggest is remove one of your RAM sticks and see if the machine will boot. I had this problem with mine and it turned out that one of my RAM slots was faulty and would not boot if both RAM slots had RAM in them.
Nov 04, 2010 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Iwant my asus motherboard driver p5k-vm serial no:85moack11970 part no;90-mbb690-gouayooz p5k vm green
Here is a link to the drivers for your Asus p5k-vm Motherboard You will need to select the operating system you are using.
Please don't forget to rate this solution.
Jun 13, 2009 | Computers & Internet
Bios Utility Setup
Tell it(The BIOS set up screen) to load default settings. Start up CD driver first. Then  Save and exit. Now install Xp disk and turn computer back on. After windows loads . Run the install disk that came with *********** board.  If I missed something or is doesn't work exactly as I stated , write back and I wil assist you farther.
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Jun 06, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
P5LD2 DOES NOT PWR ON AFTER INSTALLING CONROE 6700. GREEN STAND BY LED LIGHT IS ON...BUT DOES NOT POWER ON FURTHER THAN THAT. IT WORKED FINE WITH MY P4 HT. WHAT GIVES
Check your motherboard version. Note:
Only PCB R2.0(or higher) support Intel® Core™2 processor
You should find the information between the pci slots Or close to the asus heatsink next to the cpu.
Its quite small text, eg 1.01 1.0 2.0 etc.
If the number is difrent from R2.0 or 2.0 then your motherboard does not support the cpu.
If it is so then you have to change to a difrent motherboard.
Feb 08, 2008 | ASUS P5LD2-VM Motherboard
ASUS P5K-V - Motherboard - ATX - iG33 - LGA775 Socket - UDMA133, Serial ATA-300 , eSATA - Giga... Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
