Question about Inglesina Emma Carriage Stroller
Squeaky springs inglesina emma carriage is squeaky. what can be used to lubricate the springs?
    President:
  • 2,702 Answers
Any oil will do this but grees stayes on longer
Posted on Jul 05, 2010
Dryer is making squeaky noise when in use
Can be a few things
worn or dry drum bearing at the rear.
worn drum slides at the bottom front.
slipping drive belt.
But most likely, the tension idler pulley need some lubrication. This is a spring mounted pulley that keeps tension on the drive belt.
Oct 13, 2016 | Dryers
I need the manual for the Inglesina Trio Domino Triple Seats Carriage Stroller
Hi jane, you could request a manual from Inglesina from their website or facebook page, links follow.
http://www.inglesina.us/contact-us
https://www.facebook.com/InglesinaBabyUSA/timeline
Trust this helps, regards Alan
Apr 14, 2015 | Inglesina Baby Gear
How to fix a squeaky door on a frigidaire gallery dishwasher
Thank you for your post, friend!
I see that you need assistance in repairing a squeaky door on your Frigidaire dishwasher. The best way to quiet down a squeaky door is to pinpoint the cause of the squeak. This could be an issue with your hinges, springs, or the cables. You can use a lubricant such as WD-40 on your those parts to see if that will help alleviate the squeaking. Hope this is helpful. -Matt
Feb 27, 2015 | Dishwashers
Instructions uk
You can normally find the instructions online go to the inglesina website
Feb 08, 2014 | Inglesina Magnum - RA7 Carriage Stroller
Hello there, I`ve bought an Inglesina pram from a friend. Until yesterday I was only using the car seat, but now I`ve put the pram bit on the wheel base and I am not able to take it off. Could you help...
hi think this will help i'm sure they all connect the same way
http://www.inglesina.com/sites/default/files/447024DC_OTUTTO%20MODULAR%20SYSTEM%202010_1.pdf
Nov 01, 2010 | Inglesina Magnum CL4 Stroller
The handle on my Inglesina Zippy broke. Is there any way to replace it or fix it?
hi
I'm not sure if you can replace just the handle you may need to replace the frame but i have found contact details for inglesina in italy they cover most of the world by the looks of it they may be able to help
http://www.inglesina.com/en/consumer
here is the usa contact also
http://www.inglesina.com/us/consumer
and the instruction book on the last page is a phone number
http://www.inglesina.com/sites/default/files/ZIPPY%20STRIPTEASE%20-%20447024ZB_5.pdf
Oct 19, 2010 | Inglesina Zippy PD1- Navy Umbrella...
Very squeaky hinge on main loading door- I think caused by vibration of the plastic pulley that guides the cord attached to the spring that balances the door
I just finished fixing mine. I tried WD40 on everything that moved, but it did not help. In fact, it was worse, After reading the reply above,I wiped off/cleaned the cord and put on a lubricant such as Lubriplate grease and it totally stopped the squeaking.
Apr 26, 2010 | KitchenAid Dishwashers
HP Officejet 7310 carriage jam
I'll start by explaining some of the components you need to understand to troubleshoot the carriage system.
The Carriage is the thing the cartridges are mounted in, it slides on the carriage rail, the bushings in most newer carriages are made of plastic, (or maybe it would actually be called a polymer, or composite material). The bushings are the pieces that wrap around the carriage rail.
The carriage rail is a shiny round rod that the carriage rides on, it is driven across the rod by the carriage belt, by the carriage motor, at the opposite end of the belt there is an idler pulley, ".
In a HP printer the device where the carriage parks, (sits at), when the machine is not printing is called the service station, it is responsible for cleaning the print heads, and for capping the heads when you are not printing, (so they won't dry up). The bottom of the service station is the "Spittoon Base", ink is spayed into the base before printing to prime the heads, there is an absorbent pad in the base to soak up the ink. Note that the pad does not always soak up all the ink, so if you tilt an HP printer you can spill the ink out of the service station, (especially if it is a heavily used printer). The piece that moves back and forth in the service station is the "Sled", it was wipers to clean the heads on it, and the caps that keep the heads from drying out are also part of this assembly. The sled is moved back and forth before the carriage leaves the service statio to wipe the heads, this happens after the heads are primed, then the carriage is moved off the service station and the sled is again moved back and forth to clean the wipers.
The encoder strip is a plastic timing fence that looks clear at first glance, but has black lines painted on it. The strip is threaded through an optical sensor on the back of the carriage.
When the printer initializes the carriage has to leave the service station, or, if the machine was powered off when the carriage was somewhere else, whatever spot it is sitting in, and travel the way to the other side of the printer, and then return to it's home position which is the service station.
When the carriage reaches the side of the printer away from the service station it sets that as a reference, then it counts lines on the encoder strip as it travels home, if it doesn't see enough lines before it gets all the way to the other side and can't move any more then the printer decides the carriage must have something blocking it.
Sometimes a service station will fail in a way where the sled does not retract fully, if that failure happens when the carriage is parked then the carriage will usually not be able to leave the service station. If the service station binds when the carriage is off of the station, then the station may not be able to move all the way to that side, and will detect a carriage jam. When the service station binds you might hear a grinding noise as it's motor tries to drive the sled back and forth.
If the encoder strip is dirty the printer may not see all the lines and detect an error, often when the strip is dirty the carriage will move too fast and slam to one side of the printer.
I use water to clean the encoder strips in HP printers, water works well on water based inks, if your printer uses ink with another base you might use alcohol, but "ONLY" if the ink is not water based.
One end of the encoder strip is attached to a spring mount, if you wipe the strip starting at the end that is attached to the frame, and wipe only towards the spring mount, then the strip will stay attached to the printer.
A dry carriage rail will cause the carriage to bind, if the carriage does not move fast enough a carriage jam will be detected. Some newer HP printers use grease on the carriage rail, many models use a liquid lubricant, Use "ONLY" light synthetic or silicone based lubricants on printers that use a liquid lubricant, Petroleoum based products may melt the plastic bushings and ruin the carriage. (YES, Petroleoum based means WD-40)
some HP printers have a timing disc on the service station, and if the service station binds, or the timing sensor fails they report a carriage jam, but as far as I've seen that jam always occurs before the carriage moves.
You can use a synthetic lubricant on the carriage rail :hope this helps
Jan 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Fabric on hood and stroller seat faded from sun--new covers??
Are you sure you called Inglesina USA. They had sent me replacement parts, i.e. seat cover ripped by the airline company during our travel. The customer service is the best. The number is INGLESINA, USA INC.
363 route 46 West - Suite 260 - Fairfield, NJ 07004, USA
Toll free 888 542 1112
Email: inglesinausa@inglesina.com
Mar 05, 2008 | Inglesina Emma Carriage Stroller
Inglesina Emma Carriage Stroller Logo
117 people viewed this question
Top Inglesina Baby Gear Experts
paulcarew
Dorel UK
Dorel UK
Are you an Inglesina Baby Gear Expert? Answer questions, earn points and help others
