Question about Garden
I cannot remove the head on my ryobi S430 gas trimmer. I started it up this afternoon and the damned head flew off. This is a new trimmer and the manual is horrific.
    Brigadier General:
  • 4,044 Answers
Being new, I'd return it if the the head flew off. When you say head I see the Engine head coming off and the engine be a total mess. What part are you actually talking about. Is it plastic or aluminum? Here is a link to PDF doc that you can download. If your talking about the part with the string that cuts, which I think you are, you need to screw it back on and make sure you have a something that is locking the screw in place while you screw it down. You can use the special tool that should have been included with the weed eater or use a Phillips head screwdriver in the locking hole to hold that mounting bolt steady for you. I found a pretty good picture of the process in the manual I found here :
http://www.filemeta.com/preview.php?url=687474703a2f2f6f647265662e636f6d2f7064662f52796f62692f383930722d6f776e6572732d6d616e75616c2e706466&fname=393536312038393072206f6d2028656729&country=ca&filetype=pdf
Posted on Jul 05, 2010
I have a Ryobi s430 that starts and runs and throttles up fine when level but will stop if I tilt it to start using it even if I have the throttle pulled. Acts like its bogs down when not level.
Investigate the fuel line inside the fuel tank. Sounds like it may be split or cracked, or broken off. The line has a weighted pick up filter, and it is very common for the line to crack or break off so that when tilted, the line is above the fuel level.
Feb 25, 2017 | Ryobi Garden
Remove ryobi S430 trimmer head
it has a left hand thread which means that to unscrew it you have to turn it in a clockwise direction like putting a nut on a bolt
Jul 02, 2016 | Ryobi Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
When in operation the Ryobi S430 string trimmer leaks oil continuously. How can I fix this problem?
Ryobi told me the unit can't have the s430 trimmer bottom end raised higher than the engine at any time, or it will leak. Apparently they released a product to compete with other companies for cheap 4 cycle trimmers without much care for the end user.
Nov 29, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Does a Ryobi trimmer S430 not use a fuel mixture?
the Ryobi S430 is a 4 cycle engine. As such it has an oil reservoir which takes 30 weight oil. It uses straight gasoline in the gas tank.
Sep 03, 2010 | Ryobi Garden
One year old Ryobi s430 4 stroke trimmer will not start.
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 19, 2009 | Ryobi Garden
Installing new string line for Ryobi 4 cycle straight shaft s430
Go to www.managemyhome.com and download a free copy of the onwers manual.
Jul 09, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
935 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
